Trouble shooting ideas for why my subs don't work
4x4Hemi
4x4Hemi
Edmonton, Alberta
Hmm odd because thats how i have them, maybe ill post some pictures tomorrow for you guys?? and if their wrong or not tell me!
D33k
Las Vegas
Are you using the purple RCA outs? Have you tried changing to grey or black? I know purple says subs but should be able to test on all. I would try the grey since the black has a video out as well and wouldn't want to tie that up if you want to do a whole car DVD system
Again I don't think it's an amp thing, you said it was powering on correct?
4x4Hemi
4x4Hemi
Edmonton, Alberta
Well the thing turns on i mean, like the lights on it come on, so I'm assuming its powering on haha, id didn't test if there is power on the speaker out, but id assume so, if it comes on right?
Im not worried about doing a whole DVD set up. i probably won't take it any further then these subs besides some new speakers. Can i use any of the plugs in then?? do they all work the same?
Rambug
Get a multimeter and verify power first thing. Make sure you have a constant 12v on the battery side, a 12v on remote when the radio is on and that it isnt there when the radio is off and that there is a short to ground on you negative terminal. Next, try a different RCA output. There is still a good chance your sub output is not tuned on, so verifying that your RCAs work will help you narrow it down.
glass3222
Central PA
+1, also what is the gain on the amp set at? Have you checked the fuses on the amp with a meter?
4x4Hemi
4x4Hemi
Edmonton, Alberta
The gain is set at around low, I didn't want to turn them up really high or anything, also I don't have a multimeter right now haha I should actually run out and get one for sure. I'm I little confused on what you mean by "there is a short to ground"? Where should I ground my amp? And can I buy bigger terminal connectors because right now their ****tily put on there by the guy who did it. Haha I'll take pictures of everything and then tell me if there's something wrong with it. I'll get the multimeter and try that out first though
quietpeen
2021 TRX
Hellcat
Your ground wire should be short and grounded to the body(bare metal).
4x4Hemi
4x4Hemi
Edmonton, Alberta
Okay thats what i thought it meant. is there any spots you guys recommend grounding it?? i don't like having ground to my battery...
Also i just switched the RCAs to the grey ones, and no luck... The grey ones had never been used before, still had the plastic cap on em. so either its the RCA wire, or the amp isn't giving power from the speaker out, I'm assuming?
D33k
Las Vegas
Haven't tried new RCA cable yet? Think like 3 people suggested that on page one :)
4x4Hemi
4x4Hemi
Edmonton, Alberta
No RCA? what? haha your saying i should unplug the RCA's altogether or? thats what it sounded like to me.
I tried switching around the RCA to different ones if thats what you mean? but not a whole new RCA chord
D33k
Las Vegas
iPad fail meant new RCA chord
4x4Hemi
4x4Hemi
Edmonton, Alberta
ohh haha makes more sense, yeah ill try that, but i wanted to check my other options before i start buying new parts you know
D33k
Las Vegas
I have bout ten sets of RCAs at home, think they are like 5 bucks for cheap ones maybe less. Got like a old DVD player? Those RCAs will work just fine.
4x4Hemi
4x4Hemi
Edmonton, Alberta
Oh really haha yeah ill try those out, I'm sure i have one sitting around then, thats an easy fix haha
4x4Hemi
4x4Hemi
Edmonton, Alberta
nopppppppe wasn't the rcas... ill buy new wiring in my sub box, also I'm not sure about the wiring i have from the sub to the amp... their pretty small wires, i should probably have a bit bigger wires going through there?
4x4Hemi
4x4Hemi
Edmonton, Alberta
Haha I'm not sure on all that off hand here, I'm not at home but set up is
Head unit. Clarion vx409
Subs 2 12" type r 1222
Amp mrp m1000
I might just buy a whole new amp install kit and replace all the crappy **** he put in and asked $80 for after it was all in... This is after I test the amp out though, I picked up a multimeter but don't know how to use it ahaha what setting do I need it on to test the speaker out??
TMFMK
