Truck finally alive!
Sniklefritz
Houston TX
2009 Laramie CC 4x4
Just installed BT catch can, Moe's 85mm ported throttle body, and Superchips flashpaq. So much more fun to drive now!:waytogo:A big thanks to Matt at Moe's Performance for the great customer service and advice on the mods.
1500ram12
5.9L Cummins
Very nice. Matt is awesome to deal with.
Sent from my DROID RAZR using Tapatalk 2
Sniklefritz
Sniklefritz
Houston TX
2009 Laramie CC 4x4
Need input for next mods....What CAI should I go with???... I'm leaning towards a Vararam Air Grabber any input would be appreciated.
1500ram12
5.9L Cummins
Vararam or s&b
Gunz86
Haha, just read your thread and didn't realize you had just installed but definitely still curious about how much oil accumulation you"ll have in the catch can with the 85mm and stock air box. I recommend the VR just because I just ordered one LOL. :Rock on:
Sniklefritz
Sniklefritz
Houston TX
2009 Laramie CC 4x4
I'm planning on changing my plugs and doing a couple things tonight I've only had it on for about 800 miles but I'll check it and let u know
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Its amazing how much of a difference a few simple mods will make on these trucks. These motors have alot of potential.
TylerB
FL
Why are you changing plugs so early? These engines like the copper plugs the best, no reason to switch to some overpriced plug.
EDIT-Thought the truck only had 800 miles total, my bad. Still don't waste your money on the overpriced plugs, the copper plugs do the job just fine.
SilsHemi
Nice mods! Tuner and TB combined will make a nice difference!
audio1der
Airdrie, Alberta
If you're OK with removing the factory engine cover and have no worries about rain getting in the Vararam seems the way to go. I have rain, snow & wife approval factor to worry about so S&B it is.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Nothing wrong with the S&B, but the Vararam will fit with the engine cover in place, and rain is not an issue either. The only people that have had trouble are the guys that have body lifts and dont get a longer coupler to help it seal against the hood the way it was designed to. Look up member musclemckeester. He is lifted on 37's and has driven through water up to his grille...no problems with his Vararam because it is sealed off against the hood properly.
