Truck's likin RP a little TOO much
Shiloh 24
Kansas
5.9L gas
Well, the other day I decided "I'm gonna check my oil" to my surprise I was a ****** quart low. I immediately dove under the truck, inspected all hoses, seals, and the pan. No leaks whatsoever anywhere outside the motor, what you guys think. I've only got maybe 1500 - 2k on it since my last change?
glass3222
Central PA
Is this the first time you have used synthetic in it?
Shiloh 24
Shiloh 24
Kansas
5.9L gas
Yes, before I ran it I changed in some cheap oil and substituted the 5th quart for some engine cleanout miracle juice for about 30 minutes of runtime and then put in the RP.
glass3222
Central PA
Most people use a quart or 2 during the first couple thousand miles when they first switch to synthetic. Add some now then change your oil at about 3-4K from last oil change then you should be good to go for and oil change every 6k or so. Also, some of those cleanout additives can do more harm than good.
Shiloh 24
Shiloh 24
Kansas
5.9L gas
I'll do that, but at a hundred bucks an oil change I can't be doin this way too often. The additives I know aren't all great but after putting in crisp golden oil plus the additive and then 30 minutes later seeing that once golden oil come out blacker than Kanye West (I'm not racist, that was a joke lol) I think it was a good idea to at least get some crap outta there.
glass3222
Central PA
I think you will be ok, maybe have to add another half quart in another 1K. After that you should not use any. Your truck i s not doing anything abnormal by using some oil right now.
SilentRamAD
Cypress, CA
08 QCSB 2wd
287 4.7L
Nice to know, seeing this was my first change to full Syn I'll keep an eye out for this. Also is it just me or does the 287 only take 6qt? Yes I added oil to the filter before putting it on there. Periodically check every week just to make sure and it's reading just fine on the d.stick
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
Theres no way its $100 a change. unless he's paying someone else to do it. RP is about $8/qt. plus a nice filter and its only max $70
...unless the 5.9 gasser needs 11 qts lol
Shiloh 24
Shiloh 24
Kansas
5.9L gas
70 bucks on oil still. These are not race engines.
I forgot to factor in the other oil I used, 100 bucks included the flush of crap oil with the additive I forgot all about how much that part cost. For the RP AF's right it was around 70-75 bucks, I got a K&N oil filter as well so that had a bit to do with it. I know it's not a race engine, but the way I drive it might as well be one. I want this motor to LAST, I wanna drive it hard and this is how I repay it by keeping it well oiled or lubed or however you want to say it. :D
glass3222
Central PA
Run Mobil 1, get the two 5 qt jug at walmart for $27 each, and a filter, $70 and you have some left over for the next change.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Sadly dodge states these motors can burn I think 2.5 quarts between changes but mine has never burned a drop. The flushes tend to cause stuff to move and clog up the oil pickup from what I have heard.
cwboyjohnny24
Orlando, FL
If you have the 5.9 you may want to look at the plenum gasket. Those motors are known for it going bad and when it does it will draw the oil into the intake and cause your motor to burn the oil. I think if I'm not mistaken Hughes makes a fix for the 5.9's to where it puts a billit aluminum plate between the intake and the motor with a seal that will stop the leak.
Shiloh 24
Shiloh 24
Kansas
5.9L gas
Yea, I'm aware of that retarded design on Dodge's part. I brought it up with my boss and he tells me it's not blown.... yet, if he didn't have 30 years of experience I wouldn't believe him.
Mega-Hemi
US AIR FORCE '08-'18
Back in New York!
I'll second this one. My 5.9 used to go through 1.5 to 2 qts between oil changes. After putting the Hughes plate on it didn't use oil at all.
cheapbeater
Wisconsin
my truck used about a quart when i first switched to synthetic... it still uses a little between changes (4-5Kmi) nothing that needs to be re-added tho
mvm2
