Uconnect 8.4 & 8.4an update - 17.11.07
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I have the wires at the radio. I had the RAX jailbreak installed previously. Just need to know where to put them.
Do you still have their harness installed?
DeereGuy
Pittsburgh, PA
The schematic for my 2016 shows the cargo cam into pins 24,25,26. The backup cam would be in pins 31,32,33. Did your truck come from the factory with the cargo cam? Move the pins from 31,32,33 to 24,25,26 and see if that fixes the problem.
duunoit
EcoDiesel
Not sure what the deal was with their harness. The inputs aren't labeled correctly.
DeereGuy
Pittsburgh, PA
You could always switch the pins around in their harness i.e. Map pins 31,32,33 to 24,25,26 plug the harness in and see what happens. That's what I ended up doing. I had wired my cargo cam per factory schematics and when I couldn't get the code added to the BCM to activate the cam, I went RAX. But they wanted the cargo cam on pins 21,22,23. So I depinned the one end of their harness and mapped it to the right pins. Just found it easier to mess with the pins on something a could work on outside of the truck lol
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
WilliamS
Tampa FL
Software is radio year spacific .
If you have the vin from the truck the 15 radio was originally installed in , then go to the uconnect site , use that vin and download the SW update to your PC , then put it on a new 4gig thumb drive and install the software via the USB per the instructions on the uconnect site .
Hope this helps !
☆☆☆☆☆☆☆EDIT☆☆☆☆☆☆☆
Oh yeah one more thing , to my knowledge you will not get the OTA SW update unless your vehicle is a 13+ RA3 / RA4 factory install .
If your vehicle came with an RA1 / RA2 or you've upgraded to an RA3/RA4 your only option for a SW update is to do it manually via your USB port in your truck .
Someone please correct me if I'm wrong
Sent from my SM-G900V using Tapatalk
Mine hasnt received the OTA yet, factory RA4 2014 Bighorn. When I use Uconnects site the update it gives me from my vin is 8.4AN_RA4_16.13.13_MY13_&_M14
R.L.K.
Bristol , Tn.
Not uncommon as several have reported the same thing ....either keep checking the uconnect site with your vin# or wait on the OTA ?
NJCummins67
6.7 CTD
I believe in US it will only be OTA. At least for awhile.
NJCummins67
6.7 CTD
Worked like a charm using the RAX harness. Factory connector only had cargo cam in it at 31,32,33. Since I had the backup camera already spliced in the passenger panel as per RAX instructions, I stuck that to 24,25,26 but used the RCA plug on the RAX harness.
If I can find a source for the pins I'll do a write up on how to splice the wires in the side panel add to factory harness.
DeereGuy
Pittsburgh, PA
Glad you got it working!! The pins for the radio c1 connector and the i340 mirror jumper connector are documented over in the diy backup cam thread. M2 Mods also sells a backup camera reroute harness.
Links to pins and write up
http://www.ramforum.com/f51/installing_oem_backup_cam-53505/index101.html#post1401973
Mpgrimm2
SC
5.7L
Been busy at work. Thanks for the assist there Mike!
... See post 3 of the M² Mods thread for our camera Reroute harness...
M² Mods - From my non Flammable S7!
Metalizer
Pearland
Just got this update a week or so ago. Guess they felt we needed a screen off button on the screen and the console now.
Wish we could turn on the tailgate camera instead like the Jeeps do.
Sent from my SAMSUNG-SM-G891A using Tapatalk
dengland
2014 Limited
Still waiting here (in Central Florida) for my 2014 to update....
Deepc6
Long Island
Hemi 5.7 Etorque
I am still waiting for my 2016 to update
Fireman349
Kentucky
My 2014 updated last Thursday. Updated it while at work & only took about 45 minutes to complete.
Everything seems to be working great so far.
I'm in south central Kentucky.
Fryekenn
