Uconnect 8.4 & 8.4an update - 17.11.07
Silent425
You may consider this option Sir .
The 15.26.1 is a solid software version .
I have the same SW version , to my knowledge there's no issues with it at all , I've enjoyed it and I do not plan on upgrading my software , at least anytime soon .
Not sure on the 16.....software or the 17....SW , but I'm certin of the 15.26.1 SW having no issues .
Good luck with your decision Sir !
Sent from my SM-G900V using Tapatalk
Does your 15.26.1 have the album artwork on sirius channels or is it still the channel logos that looks way better? Personal preference but I HATE the album artwork, most the time its a faded ****** looking picture, or just the channel name with a ******** blue square! I need to get back to a version without the artwork
12sportmc
NC
It has the artwork. Using the same software on mine
Silent425
I tried a few things but I probably need to find a manual for the update and try again.
Yes you can! jus go into the apps section then click and drag the app down to where you want it on the bar, it will re position the one that is already there!
R.L.K.
Bristol , Tn.
It has the album art, but not a big blue screen ?
R.L.K.
Bristol , Tn.
Yes Sir it does have the album art ....this channel doesn't have the blue ; however, other channels do have the blue square , now I see what you mean by the blue ...it doesn't bother me , but I see how it may bother others .b819b3a3be8254c75d61cdd3ff2b4f5e.jpg
joneseysr6
NJ-NY
2015 CC Sport
christ almighty.......what sort of half assed IT people does ram employ? This update sounds like a giant cluster ****. So now we have a ****** up radio system update that is screwing up various parts of the radio interface and we have ( those with iphones ), a ****** up uconncect app that constantly launches for no reason when it connects via blue tooth.
Great job Ram, keep up the good work.
R.L.K.
Bristol , Tn.
Yep yep .
My truck came with the RA1 3.0 nontouchscreen radio , I did the conversion upgrade to the RA4 8.4NA from a 3500 2015 Ram and my current SW is 15.26.1 and everything works great , I certinly will NOT be upgrading to the 17......update , I have considered updating to the 16.16.3 Software version , but now I'm even more concerned about updating at all ?
Has anyone had issues with the 16.16.3 SW in an RA4 8.4AN 2015 Model?
At least I won't be getting the OTA notification
HEMI_Finn
U.S. ARMY Veteran
Army
N.E. Ohio
Hurricane 3.0 HO
At first I was looking forward to this update. Now I'm kinda dreading it, especially since it will be forced after a while... :(
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Well, I just read about the 2018 Ram Tungsten Edition with Apple pCar Play and Android Auto. I'll be looking for a wrecked one if the radio is still an 8.4...
https://youtu.be/2TRsmi4EdrM
Recently I've had issues with my 8.4 out of the blue. My GPS time is incorrect causing the NAV to be off and the cellular module appears to have failed. The following fix worked for me to get past a flash reboot loop but I have yet to try calibrating the GPS and my truck thinks it is stationary in downtown San Antonio...
"Hello all, As on numerous other threads, I recently purchased a used 2014 JGC Limited with Nav. Previous owner had not done any updates or even recalls. After following the directions to update UConnect, downloading the file (I had no problem with a scandisk thumbdrive by the way) I too got held up at unit 10 of 12, 1% downloaded. Same error: "Air Card Bolo install failed." I tried with car in RUN, engine off; car engine running, and even while driving. All with the same result: Radio frozen, requesting to put the USB back in.
Frustrated I turned the vehicle off and called UConnect. I got a real person at 2230 on a Sat night. They knew exactly the problem. Here was the fix:
Get back in your Jeep.
Turn the vehicle on, engine running.
When the radio says, re-insert the thumbdirve/flashdrive.
As soon as Unit #1 starts loading and gets to 1% pull the drive out. (Its okay if you get to 4-5 %)
Turn off the engine and vehicle
Open the driver door and wait for the radio to go black (Sleep)
Close the door and start up the vehicle as usual. Update should be done and all systems back to normal.
If you thought this was a fix for the NAV, the reason I wanted to do the update in the first place, it is not. The fix for the NAV, as told to me by the UConnect rep. Find an open area (Field, big parking lot) with no electrical lines or nearby cell towers transmission sources, etc. Open the drivers door, and do three tight circles, driving counter clockwise. Door should stay open the entire time. I will try it in the morning, but the first fix, was as advertised, so I'm finally hopeful. After over a year of trial and error testing, they seem to have found the tricks to fix the issues. Best of luck and Semper Fi!"
12sportmc
NC
Yep yep .
At least I won't be getting the OTA notification [emoji38]
Just updated mine. I'll let you know if any issues but so far all is good 38b491eaa582f7d6fe46614f5f4c2009.jpg
R.L.K.
Bristol , Tn.
Thank you Sir ! If you have any issues with the update you can just post it here as I'm subscribed to this thread now , also this way everyone can see your experience with the SW .
THANKS AGAIN!
EagleChief
Oklahoma
2014 Big Horn
I just updated to the "16" update last week. I haven't noticed any issues as of yet. The main thing I've noticed is that "SIRI" appears underneath my cell signal status when I'm connected to the truck. Now, with that being said, I have a 2014 8.4a Alpine set up. I do not have the NAV, or a subscription to satellite radio. I mainly use my memory card for music.
rango10
I thought those thread was about people updating their 8.4's to the 17fw, not the 16fw.
Sent from my STV100-1 using Tapatalk
Bill507
New Orleans
Still waiting on mine ..
Same here in New Orleans for my 2014, but I wont be applying anyway until i see official feedback on correcting these reported issues.. washed out backup cam display and voice volume. Both of which i use daily and dont want to deal with while waiting on a patch. And btw, big thanks to Andrea for keeping us updated; I dont mind waiting if i at least know the status.
Sent from my rotary telephone using Tapatalk
Spanka
Cummins
still nothing for me.. Houston Texas
SETEX 6.4
Port Neches, TX
How so I know if I for the update? 2014 8.4 AN
Sent from my SAMSUNG-SM-G891A using Tapatalk
soapy
Northwest
6.4 hemi
My 2015 was updated last week. Since the update My Iphone 6 will connect and everything is fine except when I try to play my music through the radio. I get the song title and timer but no sound comes out. I have tried to reconnect several times but still get no sound for music but it works for phone calls. No update on my Hellcat yet and everything is still working fine with it.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Try deleting the pairing from your phone and adding it back again.
mvm2
