Uconnect 8.4 & 8.4an update - 17.11.07
13 Ram 1500 5.7 hemi
SLT Outdoorsman
1st time? ok that makes sense. I remember when cell phones 1st started get g major updates OTA, lots of bricked phones in the early days, a bricked truck is a whole nother matter. I for one hope they perfect process before my truck updates. it's runbing good right now.
R.L.K.
Bristol , Tn.
Yep yep
Sent from my SM-G900V using Tapatalk
RocketFoot
Southwestern PA
Wonder if you have to have the most current update in the radio for it to get the OTA update? I have a 2013 with RA4 but it is not on the latest version. I would suspect that the OTA wont care but maybe you guys know for sure??
RamCares
n/a
n/a
ok so this thread started on March 28, 2017. it's now July 20, almost 4 months, how long do these OTA updates usually take to roll out. 2013 ram 1500 outdoorsman, in NJ, still no hint of an update.
Hi [email protected],
Our tentative date to have the update released to all qualifying vehicles is August 2017 however this is subject to change. We apologize for any inconvenience this causes and appreciate your patience!
Andrea
Ram Social Care Specialist
HEMI_Finn
U.S. ARMY Veteran
Army
N.E. Ohio
Hurricane 3.0 HO
My 2014 is up to date with the exception of this current one. Apparently it makes no difference.
NJCummins67
6.7 CTD
Andrea
So here's a question. My truck is a 2014, but my radio is a 2015. Will the update be for the radio year or truck year? I would assume the radio year.
R.L.K.
Bristol , Tn.
@ramcares
Software is radio year spacific .
If you have the vin from the truck the 15 radio was originally installed in , then go to the uconnect site , use that vin and download the SW update to your PC , then put it on a new 4gig thumb drive and install the software via the USB per the instructions on the uconnect site .
Hope this helps !
☆☆☆☆☆☆☆EDIT☆☆☆☆☆☆☆
Oh yeah one more thing , to my knowledge you will not get the OTA SW update unless your vehicle is a 13+ RA3 / RA4 factory install .
If your vehicle came with an RA1 / RA2 or you've upgraded to an RA3/RA4 your only option for a SW update is to do it manually via your USB port in your truck .
Someone please correct me if I'm wrong
NJCummins67
6.7 CTD
Well got bored and stuck the USB in the slot and WHAALAAA!!! It worked. 17.11.07 is installed. Just waiting for the UConnect Access stuff to come down and all should be good.
The only bump I discovered is when I put the truck in reverse the cargo cam shows on the screen. I believe that has to do with the 15 radio in a 14 truck though. My reverse Cam was always in the mirror only. And in 15 it went to the radio. Maybe different wiring. I'll have to look into that.
NJCummins67
6.7 CTD
Screenshot
duunoit
EcoDiesel
Do you have a backup camera option in the controls or apps folder? I know it won't work because it's not wired that way, but is it there? Thanks!
NJCummins67
6.7 CTD
Not backup camera but cargo cam has an app.
duunoit
EcoDiesel
Yeah, realized that was the camera you were talking about when I reread your post. Thanks for the reply!
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
I didn't think the 3 video inputs got swapped around until the 2016 year radios. Are you sure you got a 2015 radio? What is the PN reported by the dealer menu?
Hot + cold + frt Defrost for 3-6 secs
Here's are what the 13-15 Ra3/Ra4 radio inputs were as far as I know...
______ (Sig / Sig Rtn / Shld)
Backup Cam: 31 / 32 / 33
CHMSL Cam: 21 / 22 / 23
Front Cam: . 24 / 25 / 26
Can't recall which of inputs got swapped for 2016-2017 with 100% certainty? I thought it was the front & chmsl inputs if I remember correctly but I can find the reference.
But you are using the 17.x SW release intended for Canadian radios/VINs correct?
M² Mods - From my non Flammable S7!
NJCummins67
6.7 CTD
Yes. Canadian release 17.11.07. The part number is 98238619AJ it was 98238619AE on the back of radio.
Mpgrimm2
SC
5.7L
Yep. 2015 Ra4/vp4-NA PN.
I will be curious to see if anyone else reports the same video input swap issue once they update their 13-15 Ra4 vp4-NA version 17.x
All depends on whether or not they have the extra cameras or not.
NJCummins67
6.7 CTD
I'm wondering if there are pins on the radio harness that could be moved. I was looking through some of the posts to add factory backup cam.
I also have the harness from the RAX that may work.
I'll post a pic in a bit of what it looks like. When I shift into reverse the cargo cam comes on and there are 2 icons top left. One shows a truck with a cam on tailgate the other with cam on roof. The image I get is cargo cam but with the icon highlighted for tailgate cam.
duunoit
EcoDiesel
There's 3 video capable inputs on a RA3/RA4. It's relatively easy to release the pins from the connector and reassemble. The problem you have is getting the signal from the backup camera (or mirror input) down to the radio. I want to say someone here had made a harness to do it.
NJCummins67
6.7 CTD
I have the wires at the radio. I had the RAX jailbreak installed previously. Just need to know where to put them.
BGW656
