UConnect Software Update Received--What's in it?
Donutsahoy
6.4L Hemi
I’ve got a 2018 Non Nav
northvibe
Minnesota
Holy crap, I’m not crazy!
I have a 19’ classic 1500 with 8.4” non nav, UAS I think then?
My Audio was horrid and over Bluetooth the notifications are loud as hell. When turned down they don’t stay, the apple car play notification seemed to of stayed though.
I only used XM so I never tested other audio, but podcasts over my phone didn’t seem too bad quality wise. It was so bad I bought all new kicker speakers from crutchfield and had a hell of a time tweaking the EQ to get an ok sound quality out. I didn’t realize it was this common.
I have a appointment tomorrow for a vibration, maybe I’ll bring up this tsb and ask them to check. And tell them the audio is overly bass’y. The new speakers sort of helped so I almost should go back to stock :p
chrisbh17
Just an FYI - from my experience, DO NOT give them more than one thing to look at per trip. One issue will get glazed over, usually the one that really shouldn't be (like your vibration ....)
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Alright,
Just uploaded the 2018 USA Ram UAS/4c (Non-Nav) sw update for Application version 22.6 to my 8.4 Radio FW/Info thread
** use at your own risk ** ... I haven't tested it (worked for @Cstan), but verified inside the file that it is v22.6 (If you are worried about bricking the radio, take it to the dealer have them do the update)
... as I don't have a copy of the full TSB & Install directions yet (reference the UAQ 21.9 TSB for similar steps).
Edit: extract the zip file directly to a fat32 thumbdrive as-is. There should be a 'Vp4r_update' folder on the root of the drive
I will update here if I can get the UAQ file. IF YOU HAVE A UAQ 4c NAV ... THIS IS NOT FOR YOU!
Cstan
Rome, Ga
Alright,
** use at your own risk ** ... I haven't tested it, but verified inside the file that it is v22.6 (If you are worried about bricking the radio, take it to the dealer have them do the update)
I am so tempted to try this myself but the instructions I googled up call for an anti theft code.
northvibe
Minnesota
Alright,
Awesome! Thanks for uploading.
Will the trucks headunit verify if the update is compatible on its own, before updating?
FF1899
Syracuse NY
Disregard post misread above
Cstan
Rome, Ga
If I confirm it works all you do is download the file and extract it to the thumb drive (16gb) then turn the ignition to run and plug into the usb port. UAS (non nav only though!!)
Cstan
Rome, Ga
Well....after waiting 20 min :( It went through the whole process but when it restarted this is what I get..BUT everything is different now lol.
Cstan
Rome, Ga
The first two pics are after the update and the second two are in September after the crap update.
Cstan
Rome, Ga
Audio is better. I say go for it. Thanks again Mpgrimm2
PowrRam
PowrRam
Minneapolis
2018 Big Horn
3.6L V6
CStan--Does your stereo sound "normal"? Is the bass emphasis back to where it was before the crap update?
Also, it took 20 minutes for you to apply the software update from the USB. I wonder why the service advisor is telling me it takes 2 hours?
How large are the files on the USB stick?
[edit to add: Our posts crossed. I see that you say your stereo sounds better.]
Cstan
Rome, Ga
Yeah the audio is just like it's supposed to be. As far as the other gremlins in the other update I can't confirm better results as of yet . I can tell you I've been sitting in the driveway for 45 min now just jamming out because I missed the good noise :)
Mpgrimm2
SC
5.7L
Thanks for confirming it and taking the leap!
I will see if I can get the other UAQ file using the VIN I received this week unless someone else does first. IDK if the UAQ will get v21.9, 22.5, or 22.6 with that TSB update (I honestly think it's just 21.9 again but hope not)
M² Mods.
Cstan
Rome, Ga
In hindsight, I think this might have happened simply because I didn't pull the memory stick out until right after it started the reboot.
Jus10case
