Uconnect Update
FlynDutchman
FlynDutchman
Menifee, CA
Well I rolled my tune back to OEM, tried again with a different USB drive and it recognized it and installed the update. Had I been thinking straight, I would have tried the different USB before rolling the tune back since now I don't know for sure which was causing the problem. Sorry for hijacking the thread.
Its OK. I would want to know if a tune could cause a problem with the updates anyways, since I plan on tuning my truck soon.
Snake_Eyes
6.4l Hemi
Good to know thanks for the info.
Also in playing with the settings on my radio I found that in settings and display there are 2 new options for display. 1 is Blue outlined and 1 is red outlined on the screen (looks to be from the Rebel). Pretty cool for a free upgrade. Sorry about the rotated photos, don't know why that is happening.
Where did you find the color settings on your HU? I don't think I have them.
Snake_Eyes
6.4l Hemi
Settings in center bottom of the main screen, then click on the theme, theme 6 is blue, theme 7 is red.
Nope, don't have it on mine...bummer too because I hate that red/orange or whatever the hell it is! Thanks for the info.
FlynDutchman
FlynDutchman
Menifee, CA
:sorrysign: I gave you the wrong info.
Try this, pictures are below (can't get them to rotate).
1. From Main screen press Controls located on bottom left of center of your screen
2. From Control screen press Settings center above bottom options
3. From Settings screen select Display on top row
4. From Display screen select Set Theme 4th line down
5. Then simply select the color setting you want (1-7)
I hope that helps and works for you.
noupf
NY
2015 CC Sport 6'4 Bed
this is quite odd. I downloaded the file, stuck it on the usb and put it in my truck. when the screen popped up and said the file was validated, it asks me if i want to install file 15.17.5 in place of 15.17.5.
I did the anti-hack update last year some time ( no idea what the file number was )...... but the OP and the ucconect site say this update has to do with radio improvements, voice regog improvemnts and so on. It says nothing about the anti hack update i did last year. Truck has never been to the dealer since it was bought 11 months ago........
FlynDutchman
FlynDutchman
Menifee, CA
If the number is the same it should be the same file you already have. If you want to try it you can upload it anyways. It won't hurt anything. When it completes it will ask if you want to update it again, there is no need to at that point.
geneseedennis
