You are perfectly fine.
Ignore that old man or any other pontificating idiot making minimum wage
Pssst, there are far better olils, for your Hemi and filters too. but, the one you use is oil and will not harm the engine, in and of itself.,
Thank you!
UPDATE*** THIS IS BS!!! BIG O DODGE in GREENVILLE SC is a RIP-OFF!!*****
Dec. 10-26th for an engine swap, 13 days I had to pay for a rental total bill $637!!!
Dec. 28th - Called service department and explained that the truck was making an awful noise/noises from the front of the truck, notified them that my battery cover had been destroyed, my heat blanket under my hood was missing 5 clips, the clips on my radiator shroud were broken, that before the engine swap there was something mounted to a bracket beside my PC that no longer has something mounted there, that there is a DEEP GOUGE in my bumper where they removed the front end, my vinyl stripe on my hood was completely ruined, AND THERE WERE 3 OIL PAN BOLTS BROKEN OFF IN THE BRAND NEW BLOCK, AND TIRES NOW RUBBING THE INNER FENDER. Scheduled appt. for Jan. 14th.
January 14th - Returned for my front end banging and clanking when turning since the engine replacement, AND ALSO THE ABOVE MENTIONED ISSUES!!
ASCM Response... We replaced the bolts in the oil pan, AND WE CUT OFF A PIECE OF YOUR FENDER LINER. NOISE IN FRONT END IS THE FENDER LINER, and that my front end was fine, ALSO TOLD THAT UNTIL THE SERVICE MANAGER HIMSELF IS BACK FROM GETTING HIS FACE RE-ARRANGED FROM A DIFFERENT CUSTOMER BREAKING IT, THAT NONE OF THE SECONDARY ISSUES i.e. VINYL STRIPE, BATTERY COVER, HEAT BLANKET PINS AND ALL, COULD BE ASSESSED. The technician riding with me on the 14th, stated that the vinyl could not have gotten cut there because they did not have the hood off, the ASCM tells me the complete opposite of "It is impossible that it occurred here because your hood was on a padded bodywork stand the whole time" told everything was fine and good to go.
Picked up truck on the evening of January 14th, front end is still clanking and banging by the time I get it home (63 miles away)
January 25th - Took truck back to dealer on 1/25 for same front end noise, was told to schedule ANOTHER appointment for 2/5.
Feb. 5th - Returned truck to BIG O, told this time that I have to file ANOTHER 3rd party warranty w/deductible, because my PS rack, and upper and lower control arms both passenger and both driver side have failed. Also, told that "THEY REMOVED AND REPLACED THE ENGINE WITHOUT DISCONNECTING ANYTHING ATTACHED TO THE STEERING" ALSO THAT THEY WERE ABLE TO DRILL OUT THE OIL PAN BOLTS ****AGAIN**** FOR THE 2ND TIME NOW BECAUSE THE OIL PAN WAS LEAKING OIL!!!!
A BRAND NEW ENGINE(refurb. i assume) has now had 6 bolts drilled out of the NEW block, one of those bolts are a completely different size now and it is NOW leaking oil!!! my question and frustrations are HOW DID MY CONTROL ARMS AND POWER STERRING RACK FAIL WHILE SITTING ON A LIFT FOR 16 DAYS, NOT TO MENTION THAT MY CHROME STEP BARS ARE NOW BENT AND LOOSE, BECAUSE THEY DIDN'T USE THE RIGHT SPACERS ON THE LIFT AND LIFTED THE TRUCK ON THE STEP BARS.
I AM SUPER METICULIOUS ABOUT MY TRUCK..... I WORK A NORMAL MFG. JOB, AND ON MY DAYS OFF I ALSO HAVE MY OWN MOBILE VINYL WRAP BUSINESS. MY TRUCK IS MY ADVERTISEMENT SO, FOR THE DEALER TO INTENTIONALLY PUSH ME OUT PAST MY FACTORY WARRANTY IN DECEMBER, STATING THAT IT WOULD BE AT LEAST 2 WEEKS BEFORE I COULD GET THE TRUCK IN, TO COMPLETELY HAVING NO CONCERN OF THE STUFF THAT THEY SCREWED UP, AND CONSIDERING THAT i HAVE HAD MY TRUCK BACK THERE FOR THE 3RD TIME IN LESS THAN 40 DAYS, REGARDING MULTIPLE ISSUES THAT DEVELOPED SOLELY AND IMMEDIATELY FOLLOWING THE ENGINE REPLACEMENT, AND THEN TO BE TOLD THAT I AM LYING ABOUT MY HEAT BLANKET, BATTERY COVER, VINYL HOOD DECAL, STEP BARS, MOUNTS THAT CLEARLY HELD SOMETHING BEFORE THAT NO LONGER HAVE ANYTHING THERE, GOUGES IN MY BUMPER....
WHY DID/DOES MY FENDER LINERS NO LONGER FIT AND NEED TO BE CUT-OFF???
AM I THE ONLY ONE THAT THINKS THAT IS A LITTLE OFF, NEW ENGINE=OE PARTS NO LONGER FIT ON THE TRUCK AND NEED TO BE CUT OFF?
OLD ENGINE = 16.9-19MPG
NEW ENGINE = 8-12.6MPG
THERE ARE ONLY 2,250 OF THE 16' SPORT STINGER YELLOW/26L PACKAGE'S IN THE WORLD, SO... FOR THE DEALERSHIP TO EVEN ATTEMPT TO GIVE MY TRUCK BACK TO ME IN THIS CONDITION AND THE COMPLETE AND UTTER DISRESPECTFUL sERVICE DEPARTMENT AND MANAGEMENT IS ABSOLUTELY STUNNING. I HAVE REQUESTED AT LEAST 5-10 TIMES THAT I WANT TO SPEAK WITH THE OWNERS, I GET BLOWN OFF AND THE RUN AROUND ABOUT SPEAKING TO THEM.
CAN ANYONE HERE HELP???
