Unknown engine problem?
VegasMagnumRam
hemi 5.7 v8
2004 Dodge Ram 1500 63,000 miles Unknown engine problem? The problem it's having is not starting. The only way to start the truck is if I press on the gas pedal and rev it up. As soon as I let go it will stall. Changed spark plugs. Would like to know the problem thanx.
zack
pa
2004.5 packing the smarty
5.9 cummins ho
Tps sensor
zack
pa
5.9 cummins ho
Throttle positioning sensor had this problem with my ford
rbushmx
I am having the same problem on my 99 ram 1500. I changed IAC , PCV . plugs and wires. fuel filter / regulator. Will start right after I shut it off but if it cold or sits a while it just wants to crank for about 10 seconds before starting. Fuel pressure at the rail is 50psi. Any suggestions will be appreciated.
V
VegasMagnumRam
hemi 5.7 v8
At frist I wasn't but now I am getting the check engine light. So Im going to change the Tps sensor and hope that it works thanx.
zack
pa
5.9 cummins ho
That's what we are all here for try to help any body we can
EJM05
Somers, CT
440 Big Block
Should be TPS. I had this issue on my Yamaha R6 and it solved the problem.
HemiBabe
DFW
Hope ya get it squared away
V
VegasMagnumRam
hemi 5.7 v8
Now the check engine light dosen't show? I still haven't done anything but I'm about to check for any codes and will try to install a new TPS. thanx again forum
V
VegasMagnumRam
hemi 5.7 v8
Still not turning on and running?? I changed the throttle body and TPS sensor but it will still stall?? maybe the accelerator sensor??
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Lets start from the top. Are you the org owner? Its an 04 with 63k miles, whats its maintance look like?
V
VegasMagnumRam
hemi 5.7 v8
No 2nd owner !st didn't drive much.... Maintance not very well checked. I drive the truck to Utah once in a while but I have two jobs so thats where mostly the truck goes my jobs.
HemiBabe
DFW
So what exactly is it still doing? Not making a noise at all or trying to start up?
ramhunter9
P-Star Jeep Wrangler
Stop throwing parts on it first off .. if you have or had a cel it will be stored .. get it scanned and post up the code .. then we can know for sure what we are looking at .
OlDirtyJohn
Naha-shi, Okinawa, Japan
2004 Quad Cab 2500 *Sold*
you can buy your own code scanner from autozone or the like for about $40. super handy tool to keep in the truck. i know i loved mine. you can check and clear all your own codes.
Ricky91
