rickshein
- Nov 19, 2020
- 3
- 6
- Location
- Wilmington, DE
- 2021
- 5.7L V8 HEMI eTorque
Our travel trailer tail is wagging our RAM 1500 dog. Our configuration:
2021 RAM 1500 Limited (V8 Hemi w/air suspension)
Weights per the door frame sticker are:
GVWR: 7100 lb
GAWR front: 3900 lb
GAWR rear: 4100 lb
Max payload: 1359 lb
Max towing: 8159 lb
Gulf Stream Conquest Lite 238RK (length 27' 11", spec dry wt 4815, hitch wt 640)
Reese hitch 49911 - max gross wt/tongue wt: 6000/600
Tires on the TT (ST205/75R14) have been upgraded to Goodyear Endurance tires.
We had ourselves weighed on the first trip, and the weights were:
Front truck axle-3320, Rear truck axle-3960, Trailer axle(s)-4880. Actual hitch weight unknown.
The weight of the trailer is well within the capability of the RAM 1500 and the rating of the hitch appears to be correct (hitch weight is only slightly over). The hitch was installed and adjusted by our dealer. The trailer was not heavily loaded, and not in any strange way that would have changed the tongue weight much. However, at speeds approaching 55 mph, it starts to approach a white knuckle drive. It seems to sway and is overly sensitive/bouncy to uneven roads. The Reese hitch is supposed to have integrated sway control, but it doesn't feel like it.
After posting this same question to a Facebook Newbie RV group, the leading theory is that the air suspension, once its reengaged (jack mode disabled per the user manual) is conflicting with the weight distribution setup ().
For those of you out there with a 1500 Limited and a similar size travel trailer, what is your experience? Do you stick with the user manual setup? Do you drive with jack mode left on?
GVWR: 7100 lb
GAWR front: 3900 lb
GAWR rear: 4100 lb
Max towing: 8159 lb
