UO155 Code ?
bereta1
Ky
Got a UO155 code today. Anyone know the cause?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Lost communication with instrument panel cluster. Having any issues with it?
B
bereta1
Ky
Instrument cluster flickers on startup when it’s cold. Gauges are fine. It’s the LCD display in the middle where you see mph and other info. I did take the fuse out that controls the hood light. What other problems might i notice ?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
It's likely the cluster going out then. You can try the easy fix first and reset the connection on the back of the cluster. Is this a premium 7" cluster or basic cluster?
B
bereta1
Ky
I think the premium
B
bereta1
Ky
This is what I have. It’s flickered ever since I’ve had it. Bought it with 85,000m. Has 114 now. Code just showed up.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Darn, you may have your answer then. However, look up "cluster flicker" using the search on forum. I think someone posted about repairing the cluster internally not too long ago.
I'll see if I can find it too...
B
bereta1
Ky
RamCares - Started conversation.
B
bereta1
Ky
RamCares suggested dealer. Anyone else have an idea per experience?
