Upgrade to evic cluster 2012
JeffK
Wisconsin
I have a 2012 with a basic cluster and looking to upgrade to the evic cluster. I've been researching for about a week came accross multiple forum posts where this is a successful swap. However one thing I can't find is if anyone was able to successfully change the mileage on the cluster using alphaobd. Anyone able to confirm this can be done?
TheEnder
4.7L V8
You can change the mileage with Alfa. It is VERY easy to do.
JeffK
JeffK
Wisconsin
OK thank you. Just wanted to confirm before I order a cluster and can't make the changes without paying someone else to do it. I've made a few adjustments in Alfa and it's worked good so far.
JeffK
JeffK
Wisconsin
Do you know where to change it? Found some videos that mention insturment panel settings and I could not find an odometer option (I beleive the video was from a 2018). I did find a setting in the ecm. Is that the correct place?
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
I may be mistaken. But the i think the 2012 cluster is different than the 2013 and up clusters and I believe has limited upgrade potential.
I could be wrong when I had my 11, I looked for a while and couldn't find how to upgrade
Just a random thought
Not mistaken, the Ram trucks underwent a major update for the 2013 model year. The communication buss were all changed so the +13 clusters won't work in the prior years (09-12).
JeffK
JeffK
Wisconsin
Sp probably no hope on changing mileage myself? I did find a guy someone in the forum used. Maybe I'll go that way if nothing else.
Not sure on the 09-12 trucks but there's an AlfaOBD thread for those model years:
2009 was the first year that Chrysler went to the High Speed Can Bus
all of the Rams & 2 models of Jeep had the High Speed Can Bus
In 2010, i believe that all of the Chrysler vehicles went to High Speed Can Bus
I don't know if the first High Speed Can Bus was CAN B or Can C
I gave up on Electronics years ago
calidavidg
New Mexico
Hello, I'm in the same boat. I have a 2011 and have a basic cluster. I found a used nicer cluster for 50bucks, but unsure if I can do a milage correction on the newer cluster using Alfaobd...
Any luck on a fix ?
JeffK
JeffK
Wisconsin
Unfortunately not possible with Alphaobd. Not until year 2013 or newer. I did find a guy that you can send cluster too and he charges $175.
calidavidg
New Mexico
That sucks, ok thx. The local dealer does it for 150 here may just go that route.
Skyjockey
Lowell MA
2019 Warlock 4x4
3.6L
When I had my 2012 I found this to be the case as well. There were people on ebay that you could send it to and have it adjusted. Even trying to change the radio was an ordeal. Just my luck that 2013 everything changed and made upgrades so much easier for everything. When I bought my 2019 I made sure it had the best dash/radio so I wouldn't have to go thru this again
DripJust
Canada Ontario
Can someone clarify if they a tually had success putting the 7" premium evic that has just the 1 connection plug on the back into a pre 2013 ram that came with the 3.5" evic with the 3 connection cables?
2009 - 2012 Ram radio should all be interchangeable
Another name or group name was called:
MYGIG Radios
I will post what i know about Dodge Ram 1500s
Beginning in 2009, ALL Dodge Ram 1500s came with the High Speed CAN BUS C radios
( MyGIG radios run on two different Bus systems, a low speed Bus (CAN B) and a high-speed Bus system (CAN C). MyGIG radios designed for a high-speed electrical bus will not work on a vehicle with a low-speed bus, and vice versa ).
The MYGIG Radios came in basically
130, 230, 430 had 3 or 4 models, 730 had 2 models
( 430 & 730 models, would have touch screens, some might have Navigation )
some model names:
RES 130, basic radio, RESs 130 had Bluetooth phone
REN 430, RHB 430N,
RER 730N, RHR 730N
you can find more information on,
Infotainment com mygig radios ,
it covers US & other Countries radios of that period of time
jawzs2
Air Force
South Jersey
Does the 2011 and 2012 cluster have the tpm reading on the cluster ? My 2009 Laramie did not and was wondering if I could put a cluster from a 2012 in my 2009 ?
I have a 2011 and it does have the tire pressure screen that you can navigate to.
So does my 2010
