V10 Misfire?
TheShadowCat11
Wisconsin, USA
V10
Hello. I have a 1995 RAM 2500 with the 8.0L V10. I have had an issue for the past couple thousand miles, what happens is at a certain RPM (I'm not sure what RPM exactly, it doesn't have a tach) it will throw a check engine (code 43, OBD1) and run rough. I fix this by putting it in neutral and shut it off (it's an automatic), then I restart it right away while still rolling, which fixes the problem temporarily, and continue on my way. I have been avoiding this issue by avoiding that RPM range, it always happens between 25-30 MPH, and between 55-65 MPH. I've obviously just been ignoring the issue, but I'd like to fix it now. Any ideas?
RandyMiner
RandyMiner
V10
My Uncles truck does the same thing, have you figured anything out.
Thanks
Joep42
3.6 V6
Find any fix for this? I’m having the exact same issue.
