wandering after lift, wheels and tires
Mike Daley
Salisbury, MA
So I have a 2012 ram 1500 4x4 and I just installed my 3" Rough Country lift with 20x10 -12 Mavericks and 305/55R20 Toyo Open Country AT2's. I absolutely love the way the truck looks but I am experiencing some wandering and slight bump steer. I had the truck aligned with the stock wheels and tires the morning after I installed the lift and it drove fine so I know its the wheel/tire combo making the truck wander. Obviously the wider wheel and tires make a difference in how the truck handles. But my question is, what can I do about this? Is there any way to make the truck drive better with the new wheel/tire combo or am I SOL? It's pretty annoying and I was hoping that I could add dual steering stabilizers to help my issue. Or maybe get the truck re aligned with the new wheels and tires if that will make a difference. I'm new to the IFS world. I've always had 3/4 and 1 ton Cummins trucks and went half ton because I was just fed up with diesels and didn't need a heavy duty truck anymore. I used to just throw the camber out and add dual steering stabilizers and that usually took away my issues.
Docpaulo
Try rotating the wheels... it sometimes helps...
JB1
Houston, Texas
You got something wrong, I have an 8” lift and 37’s and my truck doesn’t wander. Is the alignment correct?
M
Mike Daley
Salisbury, MA
I had the alignment done after the lift was installed but I still had the stock wheels and tires. I set up another appointment to have the truck realigned with the new wheels and tires incase for some odd reason that is making the difference
M
Mike Daley
Salisbury, MA
So I have a 2012 ram 1500 4x4 and I just installed my 3" Rough Country lift with 20x10 -12 Mavericks and 305/55R20 Toyo Open Country AT2's. I absolutely love the way the truck looks but I am experiencing some slight wandering and bump steer. I had the truck aligned with the stock wheels and tires the morning after I installed the lift and it drove fine so I know its the wheel/tire combo making the truck wander. Obviously the wider wheel and tires make a difference in how the truck handles. I also just got aoter alignement today with the new wheels and tires and they found that the drivers front tire was slightly toed out, so they corrected that. But my question is, what can I do about this? Is there any way to make the truck drive better with the new wheel/tire combo or am I SOL? It's pretty annoying and I was hoping that I could add dual steering stabilizers to help my issue but I dont think those exist in the "rack and pinion" world. I'm new to the IFS as I've always had 3/4 and 1 ton Cummins trucks and went half ton because I was just fed up with diesels and didn't need a heavy duty truck anymore. I used to just throw the camber out and add dual steering stabilizers and that usually took away my issues.
Gary2
S Jersey
If you have true Bump Steer that means you have a worn component in the front end . Steering Stabilizers are a band aid when it comes to bump steer, its just hiding it not fixing it . If you have a shimmy that can be any number of things causing that ,especially on and independent suspension front end .
Buzz
Connecticut
2006 Power Wagon
Hemi 5.7 pullin the War Wagon
Please explain "throw the camber out"
JB1
Houston, Texas
Post a pic of your cv axle and steering angles
M
Mike Daley
Salisbury, MA
it drove 100% like a new truck before the wheel and tire install. Zero play in the steering wheel or tie rods and ball joints
DodgeCity
California
Well there’s your problem.
M
Mike Daley
Salisbury, MA
It's actually not the problem. Had it realigned yesterday and it's still **** it. In fact, the messed up and now my wheel is crooked so now I'm going back again today to get that straightened out
WamBam
atlanta
any update on your situation? I have a 12 1500 with a 4inch lift and 35's and my steering is super loose and wanders on the road with bump steer. ive tried looking to what to fix or upgrade and get rid of the problem but haven't found anything
No members online now.
Fryekenn
