Want to go to limited slip.
01rammer1500
After months of work, i finally got my motor built and swapped into my truck. It has the following mods:
M1 intake
R/t injectors
Mopar performance valve trane (springs, keepers, etc)
Harlin sharp 1.7 roller rockers
Comp cam with custom grind
Etc etc etc.
Tranny and gears are still oem.
Gears are 3.55 but the truck hauls ass now so i dont want to change em.
My truck has the 9.25 rearend and now all it does is fry my passenger side tire everytime i stomp it. Whats the best way to go about converting to a limited slip?
rowdyram
magnum 5.9
Buy a LS carrier and I would recommend doing a full bearing kit.
Some good options for your set up would be a auburn locker Detroit locker or a Yukon.
I've found the Yukon's to be noisey but work well.
I'd also recommend doing some trans work to compliment your engine mods and deal with the stress of the added power and posi.
Stegs
1998 Dodge Ram 1500 4x4
5.2L 318 C.I.
just my opinion but i went with a spicer limited slip unit
Works great, no complaints here
also, id agree with the trans mods to help with the new power
a trans cooler (if not already done) would be #1 on my list
mda8569
Vandalia Ohio
5.9 magnum
Hey rowdy, don't know squat about diffs, what is the carrier? It's not the whole unit is it? Is the carrier inside the pumpkin? Would a limited slip come with a carrier or do you have to get from yard or dealer?
rowdyram
magnum 5.9
A real LS posi or locker will be the whole carrier. Its in the pumpkin. The part the ring gear bolts to.
Some Lockers install in the original carrier and 99% of those are crap.
rowdyram
magnum 5.9
Those are good too. They are the factory type track lok/ power lok
mda8569
Vandalia Ohio
5.9 magnum
Thanks rowdy. So would a power-trax be one of those?
rowdyram
magnum 5.9
Yes I've ran them and broke them they work OK for a while with mild abuse but I guarantee you'll be rebuilding it.
An getting all 4 pins and springs in there is a pita
Merc225hp
NA
truck
gas
Here is a factory trac-lock also called a carrier. In the one photo you can see the clutch discs that like to fail. Also one of the retaining clips that break.
Stegs
5.2L 318 C.I.
Those are good too. They are the factory type track lok/ power lok[/QUOTE]
like i said, cant complain....great product, very quiet, no issues ever with it:favorites13:
Stegs
5.2L 318 C.I.
How much work is it to install the Spicer you have stegs?
im not 100% sure
I had it done with my 4.56 gears
I have receipt in my truck, i can look
tommyboi87
houma louisiana
5.2 Magnum
I already have it regeared. I should have thought about that when I had the rear apart lol
