Water/**** kit install pics
UNBROKEN
2012 Ram R/T
Finally got around to finishing this thing up today. The kit is from Alcohol Injection Systems and uses a 3 gallon tank with the pump mounted to the tank on the bottom.
I put it in my tool box in the bed with some other stuff to keep it all clean and out of sight.
Another shot of the tank mounted. I ran the power wire and -4 hose to the passenger side and passed it through the floor next to the hose from the air tank. I used grommets on both the tank and bed floor.
Here's where I mounted the nozzles. I had dedicated bungs welded to the new aluminum piping just for this kit. All the hoses are -4 braided stainless and you can see the Y-block I used instead of the supplied T just because I thought it looked better.
Fuzzy pic but you can see where I had another **** added just behind the BOV to run the boost line to the sensor the fires the system up by the firewall. I had that hose made myself...it wasn't supplied with the kit.
I put the supplied LED light right next to my boost gauge. Obviously it's only on when the system fires off.
And finally....had to have something to put in the tank. I don't trust washer fluid to be consistent so I grabbed 5 gallons of methanol to mix my own.
Grabbed a couple gallons of distilled water, mixed it up and the system fired perfectly on the first test.
And....that's how I spent my day today.
KozzyJr
Ontario, Canada
what kind of boost levels are you working with. and hows the tranny holding up
UNBROKEN
UNBROKEN
2012 Ram R/T
Just 7psi right now. Once I get a built trans in it I plan to pulley it up to 10-12.
KozzyJr
Ontario, Canada
pretty sweet man. i like the attentions to small details you do. check out ats transmissions they build some stout units
jojo750
south carolina
v6
pardon me for asking, but ive seen many of your threads about your truck, but havent had time to read all of them. so i have to ask...
what kind of power are you putting to the wheels?
UNBROKEN
UNBROKEN
2012 Ram R/T
It's a mild build IMHO...should make right around 500 at the tires +/- a few.
I planned to dyno it by now but I moved to Cali and didn't factor in this 91 octane gas....it's tuned for 93.
Now that this kit is on I don't have any detonation worries so hopefully I can get it strapped down before too long.
reddot
Wolf Point, MT
5.9 cummins
any issues/back ground checks to get the ****? This is whats holding me back from doing it on my cummins is getting my hands on it to keep the tank filled.
UNBROKEN
UNBROKEN
2012 Ram R/T
Nah...you can buy it across the counter at any race gas shop. 5 gallons was 44 bucks.
