Water Leak
Grim
I think my rear window or sunroof is leaking (2014 crew cab outdoorsman). My son was playing with his seat belt and noticed the last two feet of the rear seat belt were wet. Any ideas? Thanks!
ExpressRules
Southern New Jersey
2019 Big Horn Crew Cab
Check the 3rd brake light on the rear of the cab. People on the forum that have had similar problems have found the gasket around the housing was damaged.
Sir John
Buffalo, NY
2016 1500 Rebel "Mopar 16" Special Edition
Yup...most likely this. ^^^^
Ratket
Arizona-
buy some black silicone.. get a Phillips... remove the 2 screws... re seal.. and put back together... mine never leaked.. but I wasn't going to risk it..as stated above.. it's the third brake light.
gofishn
Iowa
hemi 5.7L, 345 cu in
This is so common, yet why why has Chrysler not addressed?
OP do what has been suggested by everyone here. Even if it is NOT yoru problem, it will prevent a KNOWN issue from occurring.
THough, my money is this is the fix you need.
Dave
Sir John
Buffalo, NY
It's definitely not just Chrysler. Last year I jumped over from F150s and they have the exact some problem with the leaking 3rd brake lights. I've been reading about it on the Ford forums for years and it's fixed the same way RAM "fixes" theirs....silicone sealant on the light housing.
arod412
Philadelphia
Yeah a try to do as soon as possible. You don't want that water leaking all the way down.
Truck name: Rampage
2012 Dodge ram 1500 Quad Cab Big Horn 4x4
*Bilstein 2.8" front
*Bilstein shocks on rear with 1" spacer
*Pioneer AVH 4300DVD head unit
*Polk Audio Dxi350 dash speakers
*Kicker 40CSS654 6 1/2" door speakers (x4)
*fox box 2-12" speakers holder for rear seats
*2-12" alpine subs (swe -1243l
*500 watt alpine mono sub
*LED 3rd tail light smoked
*Spyder LED smokes tail lights
havent even started on the engine..lol
joel29m
It's the 3rd brake light. Dealers are known it's happening, they changed mine out free of charge
7777xm
Covington, GA
Not an uncommon problem. Them pesky 3rd brake light gasket. Seems like most don't hold up to the higher pressure water from car washes. Rams are not the only trucks that do this.
As others said, silicone that thing up.
G
Grim
One of the reasons I switched to a new Ram was that my F150 constantly leaked. I'm sorry I spent so much money to get the same problems.
Jnoahr
Same Issue
I have a 2015 with 7k miles and just found 1.5" of water under the rear seat in the passenger side storage well. AWESOME!!!
joshhhh
