Water Pump Replacement
Resqguy
Anderson, SC
Hi Guys,
I have a 98 Ram 1500 with a 5.9 and ~180K miles. I have only owned the truck for a little over a year. It looks well cared for but I don't have receipts. It seems to run fine. Starts easy and runs smooth. I know it won't have the power of an SRT Challenger but it doesn't overwhelm me with torque or power.
There is coolant leaking from around the water pump shaft. The truck ran fine at normal temp before the leak.
Time for a new water pump. My question is about putting together my shopping list. What all is required to replace and what else should I replace while I'm in there? I will check out the rad, but it would likely be repaired locally anyway. I'll probably order parts online.
Thanks, and is there anything else that I should look at while in there?
Moparfanatic21
U.S. Marine Vet - 0321, Now a Doctor...of Vehicles
Get a gates water pump, bypass hose (should be metal with a bracket), and might as well fo the timing chain (only a few more bolts) with a cloyes double roller, and finally a 180° thermostat. :)
Reactions: Mop
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
^^^^Yep. lets see if we can save you some grief. You can find plenty of cheap aftermarket water pumps. i.e. Airtech. I get mine from Partsgeek.com I can choose cheap replacement, good replacement or OEM quality replacement. Gates is an excellent aftermarket pump at this time. "I" would also replace my thermostat, upper and lower radiator hose, heater hoses and serpentine,,,unless they were replaced recently. And of course the correct coolant. Fitz
Reactions: Mop
R
Resqguy
Anderson, SC
Thanks,
So far the biggest single expense is the purchase/rent of the tool to remove the fan clutch from the pump. Spending and extra $10 on a quality pump seems like a no-brainer. What do you think of the Delco brand?
Fitz-0518
Veteran 66-68
Central California
Thanks,
Sorry but I do not know anything about the Delco brand. Who is selling their brand?
SportRam00
Joppa, MD
Magnum 360
I have no problems with Delco brand parts. Used them in a few vehicles with no problems. Definitely do what they said above. If you're going to do the timing chain, you will also need a puller for the crank pulley. I vaguely remember people saying don't us a 3 jaw puller because it can warp the pulley. I think there is another style puller that uses a series of screws that is the recommended tool. Also, remember to get a new timing cover gasket.
