Weight Distribution Hitch Drop
Bramic71
Pace, FL
Hello. I have a weight distribution hitch from my old 2001 Ram 2500. My 2022 Ram 2500 4x4 seems to sit much higher than the old truck did. My current WDH is not going to have enough drop for the travel trailer we will be picking up at the end of the week. I plan on getting another WDH with adjustable drop. What in your opinions would be a good drop length for this truck to use for a travel trailer? Thanks
Measure the difference between the tongue height of the trailer and the bottom of the truck receiver account for about 1.5"-2" of truck squat. Guessing you'll need about an 8" drop unless you put bigger tires on the truck.
JayLeonard
6.7 L Cummins
The WD hitch I have (Equalizer E4) has an 8 inch drop which makes the ball just about even with the receiver as far as height goes.
My TT rides just about level.
Razzman
Southern Arizona
2020 Limited CCSB
Same here with my e4 as well, had to add an 8" shank too. And then readjust after putting on taller tires.
Bramic71
Bramic71
Pace, FL
Can you not just change the shank on your current WDH? I don't think I've ever seen a WDS that you can't change the shank.
That's a great idea. I'll have to seeifi can find one. My hitch is 24.75" to the inside top of the receiver. Called the camper dealer today and he said the coupler is about 23" to the top. I don't see a camper coupler sitting that high when level. I guess I'll have to see for myself when we travel there on Friday. My other camper wasn't that high I dont believe.
Bramic71
Bramic71
Pace, FL
Nice! Thank you for the reply.
JayLeonard
6.7 L Cummins
I wouldn't change anything until you hook the new rig up.
Besides it won't hurt anything to pull it home without the setup being perfect. You can figure it out then.
