Weight Ticket Confirmation
combatgrunt
Littlestown, PA
6.7L Cummins
I went and weighed my truck and trailer want to make sure I got this right. I used a CAT Scale for the weights same one never done this before want to make sure I understand this correctly.
So if I'm correct my trailer weight: 1, 791lbs??
Max load on trailer 7,000GVWR= 5,209lbs??
2022 Dodge Ram Mega Cab Laramie Longhorn Single Rear Wheel
Scale Weight Truck: All Fluids Full me and wife in the seats.
Steer: 5,240
Drive: 3,420
Trailer: 0
Gross: 8,660
Scale Weight Truck (7 Gallons Short of Diesel (1Gal=7lbs x7 Short=49lbs) & Trailer ( American Trailer/Wood Deck Car Hauler 18ft 7,000GVWR Dual Axle) Bumper Pul
Steer: 5,140
Drive: 4,460
Trailer Axle: 900
Gross: 10,500
Weight Difference: 1,840lbs - 49lbs from diesel= 1,791lbs
Yes your maths is correct, there's some rounding off the numbers from the scale but for conversation sakes your trailer is 1800 lbs and you can load 5200 lbs on it.
You use the trailer axle weight plus the tongue weight on the truck to get the total weight of the trailer. Then it's the tongue weight divided by the total weight of the trailer to determine the tongue percentage.
