Weird noise coming from the speaker(s)
kevlar017
MX
Hey whats up. I recently noticed that there was this weird noise kind of like vibrating noise coming from at least one of the speakers in my 09 ram. At first I thought that the aux would do it but now I noticed that it does the same when it is beeping when I don't have seat belt on. Do I need to replace speakers or can it be fixed? Everything is stock as far as I know and it has the alpine sound system.
Sent from my SM-G935F using Tapatalk
TomT
SoCal/OC
Start by using the balance and fader controls to figure out which corner the noise is coming from.
K
kevlar017
MX
Thanks for the reply,I hadn't noticed that someone had replied. I haven't thought about that. Will try it
adurm
FL
2015 RCSB
I'd suspect a torn or dry rotted surround considering they're nearly 10 years old.
autokraftgt
Hemi 6.1
Check the cone to see if it is still attached to the rest of speaker
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
9 times out of 10 something fell through the grill on a dash speaker and is sitting on the mid range driver. Pull the grills off and vacuum or low psi compressed air after visual inspection
