Westin Nerf Bars with Mopar Hardware
bpm413
NY
Hey there, so i got a good deal on slightly used westin nerf bars. I have the mopar nutserts installed on my truck, 2016 big horn. The bars didn't come with the bolts. I used the mopar bolts for the 2 bottom holes and they seem to be pretty secure. My question, is there some sort of nut plate or something i could use to secure the top of the bracket into the oblong hole at the top? Thanks 20191019_142602.jpg 20191020_145424.jpg 20191020_172010.jpg
MADDOG
Living in a Firepit
Find some clip nuts:
KeepRight
ExFalconFxr
US
EcoDiesel
My N-Fab's had similar "clip nuts" as listed above. I'm sure if you contact the manufacturer, they'll sell you a cheap hardware kit for them.
Your can find those nut plates at any auto parts store... Take the bolt with you.
MADDOG
Living in a Firepit
Hey tough to tell but they look solid. Have you looked at westin installation instructions? Ya know, seeing what they referenced.
Good idea. I bet the size of the hardware and thread pitch may also be reference.
My 3rd Gen MegaCan and both 4th Gen 2500s had clip nuts in at least one mounting hole. The other hardware mounting points had nutserts in them.
slickracer
PA
2018 Big Horn Crew Cab
Best looking bars out there, in my opinion.
B
bpm413
NY
Thanks for all the replies. Westin said they only sell the whole hardware kit that includes brackets and all the hardware for $58. I will try the clip nuts with a thick fender washer or keep looking for a nut plate. Thanks again
KeepRight
ExFalconFxr
US
EcoDiesel
You can make a much better set up for hardware from a good auto or hardware store.
UPDATE: I had to replace my suburban's nerf bars way back when. I went to the hardware store... It took a bit but that set up lasted another 125k miles...
