What are the bolts for the center console called?
WadXpress
HEMI
I’m doing some things and need a longer bolt but don’t know what thread this is. Every other thread is a different size. I can just drill it out and use a normal bolt but was hoping to just find this bolt at 2” or 2 1/2” long.
It’s from a center console.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Looks like it is threaded for plastic if that helps?
W
WadXpress
HEMI
Is it one of the 2 screws that go directly under the climate controls
This one bolts the cup holder and black tub down in the center console. I’ll have to actually double check it’s the same screw. The one I took a pic of may of been from unbolting the ac tuning from under the console but I believe they are the same
W
WadXpress
HEMI
I need to extend the bolt in the center section. I’m making a different style tub work for a little project I’m working on
18harvest
huntsville
Any self tapping screw would probably work.its plastic so a regular course thread sheet metal screw would also work.if you ever went back to stock just use a shoter version of what you get
W
WadXpress
HEMI
Ok perfect thank you
I am not positive, but there is one screw in there that is Gold Colored.
I have thought that it might be a GROUND Screw
each piece of blue tape, is where a screw goes
The one by itself is the gold colored screw
the blue plastic is the cigarette lighter
18harvest
huntsville
All console tray bottom and lid screws I have seen are that color I don't know why.they are definitely not grounded to anything though.
Dusty
Rochester, New York
If you are wondering the technical name of that style hardware, it is a thread rolling screw especially made for brittle plastics. The particular style is very common in the automotive industry, although not unique.
Regards,
Dusty
2019 Ram 1500 Billet Silver Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 3 June 2018. Now at 73982 miles
W
WadXpress
HEMI
Regards,
Dusty
Thank you. I’m a pipefitter and work with steel so I never come across this type of fastener.
