WHAT DID MY 2000 DIESEL JUST DO.
PaPitt
Stephenville TEXAS 76401
5.9L
So yesterday. It was about 45* OUTSIDE. My Dodge truck is a D250 Diesel . with 365000 miles on it.
It's a really nice Pick-up yet. I bought it at 165000 mile with the Injection pump out on it .
So I had a rebuilt injection pump put on it . It has had the fuel filter changed once a year , along with it's other maintenance .. WHICH IS ABOUT ONCE EVERY 5000 MILES.
BUT WHEN IT started up yesterday I was blowing White smoke out the exhaust .. I went ahead & Drove it out my Driveway . & Turned it around at the mail box & drove it bad to the house.
I even wondered if it was going to make it back to my house .. It had no throttle response .
It did not set the check engine light .
It's had about 3 Lift Pumps put on it .. I'm sorry I don't like the new in-tank Lift pumps .. SO I just put the original style of lift pump back on the Block Side. This pump most likely has about has got 50K ON IT.
I Worked for Dodge dealership for 10 years when I bought this truck. I was a service advisor..
We worked on 100 diesel pickup a week ... So I've seen a lot of Diesels.
But it's been12+ years since I worked there. & I cant remember what We'd have called this issue.
Later that same day I came back & cranked my pick-up & it ran perfect .. No miss or no White smoke .
SO WHAT Do you think it was when my truck did this Bad smoking issue.
..... I would think an injector . But how could an injector correct itself.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Should of smelled the smoke and if it made your eyes water and smelled like fuel you many have had an injector hang open.
P
PaPitt
5.9L
Yes I got out& walked into the White Smoke .. & Yes it smell like fuel & Not oil .
COOLANT in radiator is full & correct color. & Oil was only about a half qt low. & Truck is due it's 5000 k mile oil change.
... On another web sight a fellow member who sure has lots of good answers. He said.. it may have had the grid heater not work at all . & It cranked withnot heat to the fuel . & Yes that made it kick out unheated FUEL.
......WONDER WHAT Would keep it from doing that again.
But as the Truck sat there & cooled back off to cold temps . The next Time I cranked it hat day I believe I let the Wait to start light run it's 20 second time heat cycle & The truck cranked & ran great.
....I'd sure like to have a new set of new Injectors , but I hate to just put in $800.00 worth of new injectors. & Have a $200.00 bill to install them. .
& Only help my mileage from about .15.7 up to maybe 18.5 r 19.mpg.
It take a lot of miles to pay for that Injector replacements.
RacerRon
Missouri
I had this happen with my 2000 a few years ago. Only difference is mine ran just fine.... maybe slightly sluggish response at low rpm. Mine was an injector. I had them tested at a local shop. I was told one was not spraying correctly. It actually put a couple of quarts of fuel in the crankcase as well. Check the dipstick and make sure it has not went over full.
06 Dodge
Forest Grove, Oregon/soon Osage Iowa
6.7L CTD
I see your in TX so I have doubts the grid heater not fully cycling had anything to do with the white smoke, the reason I say that is I have done a few very cold start up in my old 2006 5.9 CTD between -20 & -27 below zero without lettings grid heater run a heat cycle and did so without any white smoke coming out of the exhaust system. Agree with RacerRon to have injectors tested by a reputable diesel shop to find out if maybe you only have a single bad injector, its also a good idea to run some injector cleaner in your fuel...
