Finally pulled the jump seat out and installed a full floor console. Really wanted to use the auto dual zone climate control that came with the radio bezel I purchased but apparently it’s not compatible with my current setup.
I think some guys used AlfaOBD to get the auto climate swap working, check the DIY Alfa thread to be sure or ask @kad
I hate clear coat. Never really looks good until u wet sand it. Hard to tell how even the coats are as well. Take your time looks really good so far.
I have been fighting with lousy lighting since it's in my basement and I wasn't buying lights specifically just for this.I hate clear coat. Never really looks good until u wet sand it. Hard to tell how even the coats are as well. Take your time looks really good so far.
Sent from my Pixel using Tapatalk
I sanded the balls out of the chrome, adhesion coat I didn't touch, a full can of high build primer so about 5 coats, 1000 grit dry sand, 1500 wet, shot color, 2 cans about 4-5 coats last one being thicker and wet. Now waiting for it to set so I can 2000 grit wet sand and see how it looks. Gonna grab 2500 and 3000 for clear and I have low cut polishing compound once I wet the clear. All out of spray cans. So far I've managed to have almost zero imperfections, now it's a matter of keeping it that way. When in doubt I sand it. So far I have like 4 hours in sanding work and about 30-45mins of actual paint.
Sent from my SM-N920V using Tapatalk
Paint is the only thing I've never tried. My ocd is bad enough it has been goin well. Actually impressed with how the color coat came out. Might wet sand and shoot another wet coat, than it'll be damn near perfect. Clear coat, that's a whole other ball game for me. I normally just bed liner **** and call it done. So this is weird for me lolSo the moral of your story: if this doesn't work, it's not for the lack of trying! Man, I got tires just reading ... hats off to you and good luck!
TXCOMT
I know nothing about paint, so I'm definitely going to look into a coating. As for clear coats, I do know the 2 component ones are the ones that lay smooth and glossy. The spray cans are only one component so I'm not sure. I'll toss a tack coat down and than lay it nice and heavy, almost to the point it sags, but not quite. Than sand and polish till it's good from farYou know, it might be a good application for using a paint *coating* instead of trying to clearcoat it. Im not sure if the coating will leave it glossy, though.
Something like Optimum Gloss Coat, GTechniq Crystal Serum, etc.
Im with you though...ive done some basic painting before and clearcoat is a mystery to me. How the hell do you get it to go on perfectly smooth without sanding it? Because if you sand it you are essentially 'starting over' with no clearcoat.
..... Than sand and polish till it's good from far
Exactly!20/20!
It looks perfect from 20 feet away at 20 mph
I have to say you're being nice, I have some words I can use and none of them are acceptable for the forum. [emoji16]If someone says anything negative about it I got two suggestions, either hand them a can of paint and sandpaper or tell them to "**** off".
Jay
