Jim S
Louisiana
5.7 eTorque
Used it to take my camper portable black tank to a dump site.
faross
Fl
5.7 l
Well let's see just got my 22 1500 classic less than 2 months ago a tradesman no extras soo
Started with a aftermarket head unit got the atoto f7we sounds good enough from me old fart likes it soothing .
Moved on to a set of stainless running boards added a cheap cover for now will replace with a trifold hard cover later . And this weekend applied the huruliner to the bed turned out pretty good if I say so .
ThunderMug95
North Prince George, VA
If it works out can you send me a list and the link for Alfa info?
Replaced the hood latch with Mopar one with sensor. I was factory wired from latch to the TIPM. Used pin5 and ran to BCM C1 connector, pin#11. ( This was excruciatingly painful to get to this connector for a 6’4, 250lb guy. Pin #6 went to body ground. 10 min with AlfaOBD, replaced rubber overlays on my fobs…Done. It works.
1SloRam
Ms
I’m half your size so maybe not so bad…looking into this.
REDinAZ
Arizona, USA
2017 Crew
5.7 2wd 3.92
1SloRam
Ms
yes, decent MPG is surprisingly possible. the '17 recently posted 22 per on a 14hr rip...
Nice! those long trips get boring after a while.
I don’t really get hyped about mileage, but was curious as to what I’d get since the swap plus LT headers, manifold, tune and filter versus stock. 6spd 3.55’s.
TotallyHucked
Gainesville, Ga
2017 Sport CCLWB
It raised it nice but are you going to level out the back?
It measured dead level when I first put it all together, now that I've been driving it for a couple weeks and it's settled, it's a half inch lower in the front. So it's perfect, not touching it
faross
Fl
5.7 l
Moved on to a set of stainless running boards added a cheap cover for now will replace with a trifold hard cover later . And this weekend applied the hurculiner to the bed turned out pretty good if I say so .
Ok bed all painter cover back on and tool boxes installed
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Last week replaced halogens in projectors hi and low beam and fogs with LED's.
Yesterday, did the AGS delete, making my own bracket for it, and works like a champ. No Codes. Drove about 100 miles in highway / local roads to see if it made any difference. Was 88 degrees yesterday and trans temp never went over 171, though. One thing I did that I didn't see anyone in the videos do was remove the rubber side skirts from the shutters and put them back in place to close off sides to the coolers. Just used Gorilla duct tape to hold them in place, but think that stuff will hold permanently.
EDIT: Didn' like having the modified AGS motor mounted down low like the videos (could be a target for water splash), so moved it in behind the radiator core support, in front of the TIPM. Cable was plenty long enough and now it is a lot more protected.
My Vararam Air Grabber Intake comes in tomorrow and we will see how that goes. I need to redesign the lead in angle / ramping of the front intake piece so it doesn't block the tran cooler so much. That should be easy without the grill shutters in there and a heat gun to reform the angle.
Adamcr68
Lorton VA
Hemifever 5.7
So I searched the forum for a thread like this and didn't find anything. I figured it would be fun to have a thread that everyone can watch what everyone is doing each week.
This week I put on Steelcraft nerf bars, and right now I'm getting the permaplating put on the truck. This way it gets a real good bath.
Actually next week-Tuesday going up to Quick_Shifter’s shop to install hubs, wheels & tires- with different offset to get rid of my wheel spacers & set of Bilsteins. Sending my shocks to be rebuilt, should be about 4 weeks, then go back for install. I’m excited to go, always a great day at his shop & knowing your mechanic isn’t satisfied until it’s right makes the day stress free. I have said it before but would happily drive twice as far to go to Quick_Shifters’s shop-ak_trucks_pa- won’t take my truck anywhere else!
ramsare4real
FL
Oil change 5 days ago. Out RGT 5W-20 and Fram Ultra. In Redline 5W-30 (4) + M1 FS 5w-30 (3) and Fram Ultra.
OCI 8125 miles.
