- Jan 8, 2015
- 9,103
- 4,794
- Location
- St. Louis
- 2014
- 3.6 Pentastar
All of the transmission issues you mention might be addressed by TCM flashes from a dealer. All of my transmission complaints were resolved by a "quick relearn" process. The only transmission issue that required a flash of the TCM for me was the 2-1 bump you mentioned...that was a TCM flash.I bought a 2015 1500 Express Hemi 8 speed about a month and a half ago with only 29k miles. I have just over 32k miles so far and I have a few things I don't like. First, is how rough the trans shifts through 1st-2nd-3rd. It feels like its slipping under some conditions (like when the trans is cold) and shifts weird sometimes. 4th-8th is butter smooth though. Second, is how slow the throttle response is when MDS is active and I need a downshift or two. For example, if I'm cruising on the highway and I need to squirt out to get past a car, the truck seems to not want to disable MDS before downshifting. Or it will downshift but not disable MDS. Its never consistent and it makes it difficult to predict passing timing. I'm planning on getting a tuner soon mainly to disable MDS.
The trans weirdness doesn't fill me with a ton of confidence considering the horror stories of transmission failures. I also have the trans/driveshaft "bump" when coming to a stop. Its bad sometimes and it feels like the truck just got rear ended. I'm hoping it just needs the splines greased or at most a new driveshaft.
Also, the lifter/camshaft failures worry me too. You could own the truck for 150k miles and never have it happen or it could happen at 35k miles. I do not like how its a crapshoot if it happens or not.
