Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I am pulling a 40 foot fifth wheel, currently with a F350 SRW. What will I get with 3500 , or I might say why is towing capacity higher. than the 2500.. SRW
2500 has coil springs in the rear. The 3500 has leaf springs. Which are better for towing heavy. I believe they have the same axle unless you have a drw
Not to mention you will be way overloaded with a 2500 Cummins with your 40' 5th wheel. Your payload will be in the neighborhood of 2100lbs and you probably have at least 2500-3000lbs pin weight
