Wheel hub torque specs
EdGs
FL
Have what I believe is a wheel bearing going south on my 2015 1500 2wd. 140k miles.
Started noticing a little growly noise almost like tire noise from the right front wheel. Noticed it first at slow speeds decelerating. Now hear it at accelerating as well.
Very slight play when shaking the wheel, but when I spin the wheel, I can hear a light crinkly sound.
I am going to order up 2 hubs, so I have them on hand, since I think I'm at the beginnings of a failure.
Are the three bolts that hold the hub on TTY?
Can anyone give me the torque specs for these and for the caliper bracket as well?
Thanks in advance.
P.S. Had my truck on the lift checking my driveline, amd forgot to install the leak detection pump for my loose gas cap issue.
Story of my life.
EdGs
EdGs
FL
130# front caliper bracket
120# front hub bolts
Thank you very much.
When I was going down the youtube rabbit hole, I found a video where the guy said, "40 ft-lbs + 80°".
I have no problem replacing the bolts if I have to, just trying to make sure.
DILLIGAF
Canadian Forces
Canada
EdGs
EdGs
FL
Thank you!
Thank you!
Ed you can buy the Haynes and Chilton paper manuals that are good up to 2018 now.They're worth having on hand.
