Wheel offset/backspace question?
SuperTrooper
Douglas, GA
Guys, can anyone provide me with the ideal offset/backspacing needed to run a 20x10 on a leveled 1500? I'd like to minimize the need for trimming.
Also, pictures would be appreciated. Thanks a lot!
BlownGP
Houston/Baton Rouge
What size tires do you plan on running. That will determine how much offset you will need.
Even though with 20x10s. You will probably need to be in the 0 to negative offset.
BlownGP
Houston/Baton Rouge
Then you for sure going to need a negative offset
