Where do you park your Truck?
How /where do you park your truck
  • Total voters
    44
  • Poll closed .
farout75
Laurie, MO
2019 Limited
5.7 L
I don't have a garage, so it's outside. I have noticed I don't get the rust that I did when I had a garage.
turkeybird56
Central Texas
Hemi 5.7, Non E Torque
You can see it behind me.
I'm actually sitting in front of my wife's attached garage...
Wow, 2 garages, nice. I just have a lowly 2 1/2 pole barn setup. Nice hog, I had a '08 Ultra Classic, but for personal reasons, went to a Wing Trike. BOIRD thinks some of you all got friggin Aircraft hangars for Garages.
Marshall
Sk, Canada
2014 sport
Mine sits in the garage, with the camera and parking sensors i have about 1 ft of room
For some reason the wife’s Honda CRV needs more room
ColesRAM
ColesRAM
NE FL
5.7 V8
Well, it looks like the poll shows a bit over 40% of the RAMs are sheltered (garage or car port) and a bit less then 60% sit in the elements - but probably would also be sheltered if it was available. That’s from my read of the comments. I know in my case, my RAM would be garaged if it would fit in the garage. Thanks all for participating in the poll. :)
RamDiver
Marlborough, Ontario Canada
2021 DS
Wow, I have a serious case of garage envy. Some of them look cleaner than my basement shop room.
I have this small barn that fits my Ram 1500 Classic.
There's much more room than my previous truck, a 2007 Tundra DC.
The step bumper clears the log splitter fender by an inch or two. :cool:
ColesRAM
ColesRAM
NE FL
5.7 V8
Tight fit, isn’t it. My RAM won’t even fit into the garage, just to tight all around…..
RamDiver
2021 DS
LOL, I thought I had lots of room compared with my Tundra. It beats parking outside and the house garage is a no-go.
Although the Tundra was a Limited with sensing all around, it had no camera in 2007. I find the Ram with a rear camera/rear park sense is much faster/easier to park.
Last Spring, I did manage to change to my summer wheels while inside.
Well OK, I parked inside more centred, lifted the front with a trolly jack, changed the front wheels, pulled outside leaving the back end inside and changed the rear wheels.
Yes, I jacked the pumpkin.
Something was falling from the sky that day, I prefer to work inside if I can. :cool:
KoboldTaco
Los Angeles
Cummins 6.7L
As a new truck owner (2020 RAM 1500DT), I’m curious as to how many members here actually park their truck in a garage, or even under a car port type enclosure or just leave it out in the open. My RAM is too big for my garage, so it will live out on the driveway, open to the elements. Here in FL, those elements are mostly rain and sun. So, i was thinking how or where others here mainly house their trucks. Just curious, that all. Thanks.
ColesRAM
Mod, if I picked the wrong sub-forum, please move. Tx
Mine will go to the driveway soon but currently curb parking until my flooring project is complete and my girls car gets garage privilege first.
Dan Topp
Jefferson Wisconsin
When we were shopping for houses or really garages I could only think of the setup that was a struggle to fit my vette. Still had to raise trusses headers and get custom track springs cables and drums from lift master. Doors Menards.image.jpgimage.jpgimage.jpgDoubt if anyone could get me to crank this spring again,the normal side was bad enoughED066226-2BA5-463F-A4D6-6905F4B2C959.jpeg
Scottly
Safety Harbor, FL
HO 6.7 Cummins
As a bachelor I often go to work from a different direction, hence, I park in different places. Always be careful not to park in apartment complexes without the visitor permit. :favorites37:
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
Speaking of parking, mine is parked outside all year round and is typically unused for months at a time. This year I was thinking of raising it up just high enough to get the weight off the brand new tires. Any issue using jack stands under the solid axels and just leaving it up for months at a time?
I'd probably put a block of 2x4 between the axle and jack stand.
RamDiver
2021 DS
I've seen two full-sided trucks parked on jack stands for years. One in a rural residential laneway & the other at a small welding shop in a nearby village.
I know this information doesn't prove anything but provided the truck is stable and protected with wood blocks, how can that not be a huge improvement over making flat spots on the tires? :cool:
Hopefully, the location wouldn't be subject to kids or vandals fooling with your truck. That could be ugly.
Oliver Closehauf
Cincinnati
2005 Laramie
Cummins 5.9
No, it will be in my driveway in front of my garage which is detached and behind the house, and my house has a fenced in yard with security cameras and lit up like a prison at night. Thinking about a cover this year.
I was just worried about the axle tubes.
RamDiver
2021 DS
LOL,
I'm glad I moved out to the country 13 years ago. :cool:
Why not jack up your truck using a trolly jack under the frame to guage how tall of jack stands you would require with 4x4s to raise the wheels enough?
That would relieve your concerns about stressing the axles.
Dan Topp
Jefferson Wisconsin
I definitely would try to do a jack stand setup stable enough to be able to occasionally run and spin all the gears,ect.
glenn22mag
