Check out a pan for a 8 speed Jeep,supposedly they're a steel pan.I've never actually checked into it,but that's the reports i've heard on the facebook pagesWho has used the Dorman pan and what was your experience?
TIA!
I've never seen that one,but it looks to be a good option,if i was in the market for a differant pan,i'd sure give it a whirl. That's the best price i've seen on an aluminium pan for the 8 speed@Wild one , have you seen or heard about this one? I've searched from 2014 to 2020 in the jeep catalog and it comes up the same plastic pan. This one appears to be aftermarket but made out of aluminum
The Dorman pan itself didn't leak or cause any other issues for you before or after install?I changed out the original pan and filter on my Ram. I ordered from Rock Auto the replacement. It was a Dorman pan with a replaceable filter. The original filter cannot be replaced, so you have to purchase the pan and filter. Once this is done, you need only to purchase the filter.
The install is simple and easy to do. Just make sure to cover the exhaust pipe from the dripping.
Filling the transmission case with fluid is a chore. Be sure to jack up the rear about 3 to 4 inch to level the transmission. This levels the transmission and you will be able to properly fill the case.
It is easy if you have the tools. Check before you start. You cannot fill the transmission from the top because there is not a shaft.
Man have they gone up in price from when i bought my PPE pan a 1/2 dozen years ago.I paid $250 Canuck for my pan with 3 extra filters. Canadian Diesal,is the cheapest place in Canada to get them.2014-2022 w/ZF-8 Speed Transmission Heavy-Duty Cast Aluminum Deep Transmission Pan
Transmission Pan - Heavy-Duty Cast Aluminum - 8HP70/8HP75 Features:Cast-aluminum construction Increased heat dissipation Reduced oil temperatures Increased fluid capacity Stainless steel drain plug Includes replaceable filter 1/8 NPT tempeppepower.com
Dang that was a good price! I paid $280US for mine with zero extra filter two years ago.Man have they gone up in price from when i bought my PPE pan a 1/2 dozen years ago.I paid $250 Canuck for my pan with 3 extra filters. Canadian Diesal,is the cheapest place in Canada to get them.
PPE-228053010
DetailsThe factory plastic trans pan is discarded each time you do a ZF 8HP70 transmission service. Upgrade to a permanent solution with better performance benefits.PPE has engineered an exclusive cast aluminum pan with a replaceable filter (included), which means unlike the factory part there...www.canadiandieselonline.ca
I hadn't checked the price on them for awhile,so i was a bit surprised at what they're worth now.I'm wishing i'd bought 2 back then,as i've been kicking the idea around of throwing one on the wifes ChallengerDang that was a good price! I paid $280US for mine with zero extra filter two years ago.
