Will 37s fit?!!
Buffalogue
2014 1500 CC 4x4
Hey guys!! Im wondering if 37" Nitto TG will fit on a truck with a Pro Comp 6" and bilsteins up front on a 22x10 with -24?? I was originally wanting to put on big 22x14s, but after posting and researching here, it seems like those would destroy my front bearings and probably wouldn't fit even with 35s. Any info would be much appreciated!!!
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Depending on what you set the Bilsteins at (I'm assuming 2.1" or 2.8") you may end up with a slight amount of rub that a little trimming will take care of no problem. It will just be on the back of the inner fender plastic. Other than that they'll fit no problem.
Buffalogue
Buffalogue
2014 1500 CC 4x4
Awesome! Good to hear man. A lot of the 4x4 shops around here look at me like I'm crazy when I mention this combo. And I'm pretty sure I've seen a couple of trucks here set up like that.
And yeah, I'd put them at 2.1 or 2.8. I'm also putting on some Zone upper control arms for the extra angle from the bilsteins.
Thor09
Northern PA
With bilsteins at 1.4" or up you should be fine. I have 37s with bilsteins at 2.8" and plenty of extra room, no rubbing. Wheels are also 10" wide -24 offset
SilverStreak88
Houston, Texas
5.7 Eco Gasser
That sounds like a sweet setup... are planning to re-gear? I just put 35's on my truck and I feel a bit more lag.
Rzrman328
The treeline
20x12 -44 on 37x13.50....no bils...definitely rubbed.
A lil elbow grease and all is good.
Your setup is do-able.
Buffalogue
Buffalogue
2014 1500 CC 4x4
Awesome awesome!!! Thanks guys! I'm going to pull the trigger then tomorrow :D
I will definitely be re-gearing in the near future as I have 3.21s right now. I wonder if 3.92s will be enough, or maybe should I go even lower?
Revo
Canada
5.7L
I have 3.21s and when going from 33s to 35s I hardly noticed a difference. Interested in hearing from someone who's running 37s with 3.21s. Just got a quote today for $4400 CAD ($3300 US) to have the swap done by the dealer.
Wandell
Cummins 6.7
I'm sure they deal with a lot of different trucks and the Rams look like they sit low, but they have huge wheelwells. The GM trucks look like they have huge wheelwells because of all the empty space at the top, but they actually have very limited clearance at the bottom, rear corners of the wheelwells. Optical illusion.
Buffalogue
Buffalogue
2014 1500 CC 4x4
And I know this seems like an obvious question, but I just wanted to double check. When you use the bilsteins with a 6" lift, you don't install the pre-load spacers correct?
Buffalogue
Buffalogue
2014 1500 CC 4x4
Ahhh, that makes a lot of sense. Thanks man! Yeah, Rams almost look like they are 2wd.
Thatdude596
buckeyes state
2009 ram big horn
I have a set of 37s with 1000 miles on them. Toyo open country Mt 37x13.50x20. Just want 40s reason to sell
Buffalogue
Buffalogue
2014 1500 CC 4x4
picture.php
picture.php
Hopefully it will turn out as awesome as this truck!!
CuylerTech
NH
2015 Big Horn Mega Cab 4x4
6.7L
Compare the weight between the 37's and say a set of 35's. my 35" tires right now are heavier then the 37" tires I just ordered so it goes both ways.
