Will it fit
Rzrman328
The treeline
Will they fit? Yes.
Will they rub? Maybe.
This is my exact wheel setup and I don't have bils....and mine required extensive modification because they rubbed. Wish I could give you a solid answer. Worse case, you have minor trimming to do.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
They're require a significant amount of trimming. You'd need to add a body lift on top of your lift if you want to fit that setup properly.
chrisc75
Delran NJ
i have a 6in lift on 2.1 billys on 20x12 35s and they rub at full lock going up and down driveways
