Will these rims work
redram2007
Colorado Springs (Ft Carson)
Stangshcky12
Oshkosh, WI
5.9 Cummins
I have that wheel in an 8 lug
They will stick out ALOT
It's about 4.06"
The flares add 2" of coverage
Recomended wheel width for 275 is 7.5"-9.5" so running them on the wheel would be a stretch
NWRQC
When you hit the link it will show the type of rim im interested in. The size im looking at is going to be the 20x10 XD 807 Strike Chrome 5x5.5 with a -24 offset. Right now im running a 20x9 with a +15 offset wich is a little over 5.5" of backspacing on 275/65/20 nitto terra grapplers and bilstein 5100 set at 2".
http://www.rimzoneonline.com/category/801E/XD-Strike-Chrome-Call-for-availability/
If you want an idea of how they will fit on your truck just measure about 52mm (2") out from your current wheel and that will be the outward placement of the new ones. But as Stangshcky12 said "They will stick out ALOT"
Stangshcky12
Oshkosh, WI
5.9 Cummins
Actually I have them in a 17x9 so those would stick out even more
I saw 20x10 on a 4th gen sport, I wish they made them in a 17x10
Running 315/70/17
quietpeen
2021 TRX
Hellcat
What size tire are you going to run on them?
