Will they rub?
Orion
Sup guys, I'm about to order my 20x12 -44 Offset wheels to go on my 35x12.50x20 Atturo Trail Blade MT's, I'm on a 7" maxtrac suspension lift. I was just wondering if this wheel/tire combo will rub? The guys at the tire place said that they "know" they will rub. So do you guys think they will fit without any rub or will some minor plastic trimming need to be done?​
Kid's HEMI! !!
My 20x10 -24 with same lift rubbed I had to trim the lip a little on each side . I think yours would need more trimming then mine
Orion
Orion
Any metal or mostly plastic?
I wish to learn something new, what's the 50? in 35x12.50x20.
Awe gothcha, 12.5. The zero through me. Doey.
Kid's HEMI! !!
Only plastic I can take a picture tomorrow if you like
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
It may require a bit of plastic trimming but that should be it. Won't be anything too crazy. If done right, most people won't even be able to tell anything was trimmed.
Orion
Orion
Thanks Brandon!
14blackouthemi
North Jersey
I run 20x12 -44 offset on 2.5 inch level. I run 33s with only slight rub a full lock in reverse. Think you'll be good.
Orion
Orion
Thank you blackout!
Fpye
