Will this wheel/tire combo work?
talgozzine
Hey guys, as you may have seen on my other thread I just got Bilstein's at 2.8 installed with 1.5" rear spacers. I also plan to get a 1.25" body lift when I get wheels/tires.
With the setup above including the body lift, can I fit a 20x10 -25 offset wheel with 35x12.5x20 tire? How far will this stick out past the fender if it does fit?
Thanks!
Bluesmoke91
2nd GEN Site Mod
Baldwin Park, California
I have 12" wide tires on a 18x9 wheel with -12 offset. It sticks out about 2-3 inches.
Id say your setup is going to stick out a whooole lot more.
Sent from my DROID RAZR using Tapatalk 2
Soundwave
With a 10" wide wheel you're looking at 4.5" of backspacing which is the same as a 9" wide wheel with a -12 offset. Stock offset is +19 I think which is 5.75" of backspacing so you're looking at 1.25" difference. If you google "offset chart" it'll bring up all those numbers too.
T
talgozzine
Sooo, does that mean I'd have the same backspace as Bluesmoke, but the wheel would be sticking out 1 inch further and the tire another .5" since he has 12" wide tires? Sorry, still wrapping my head around this stuff.
Soundwave
Well you gotta look at it as a whole. You'll be 12.5" wide, but on the entire tire. So .25" on each side.
Same concept with 35" tall tires. You're going 2" larger than the stock 33", but since the overall diameter is getting bigger, so you're really only gaining an inch in height.
Soundwave
Stock tire size is almost 11" (10.92") wide I think. So if you were looking at a 12.50, took a ruler to it, it would measure 12.5" across. Put it on the truck and its still going to measure 12.5", but you'd still only gain .75" of outside the truck...AND inside the wheel well (for an extra 1.5" total). That's also why you needs the 0 or negative offset, to get away from the control arm.
The offset is the only measurement that is going to bring the tire AND wheel out from the wheel well together. The offset numbers are just millimeters. Backspacing is just another term for it.
The biggest help that I got was googling offset and backspacing to better understand it. It's simple when it finally "clicks".
To answer your original question simply, -25 will work, but -12 on a 10" wide wheel will also work. You're not gonna start really sticking out ridiculously until you go past that -25. My 20x9 0 offset is flush with the fender flares at the highest point and sticks out around 2" on bottom. I'm imaging you might start throwing rocks all over your truck beyond a 5" backspacing because you'd be exceeding the wheel wells a good amount. It's really hard to picture this even using a tape measure on your truck which I did for months.
A lot of these wheel places will test fit things for you too sometimes. That might be the easiest way to figure it out! Good luck!
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
Thanks!
That will fit with just the max Bilsteins but it will be STUFFED and will require some modding. But with the 1.25" you should ok.
T
talgozzine
Soundwave, thanks for all the info...
fastNugly, I agree I would not go with 35's until the 1.25" body lift was done. Also if I went with 35x12.5's it would be the Toyo Open Country ATII which is actually closer to 34.5" tall to help with the stuffed look.
fastNugly
Toronto, ON
I like how you did your homework as those are the measurements of the AT2.
If you do need pricing on those, we can get those for you :)
