Window leaking issues.
BlownGP
Houston/Baton Rouge
Not my truck but a a friend has a 2019 Ram.
Water is leaking from the front area where the buttons for back window and emergency call button is.
Anybody else this issue?
DRkNESS
South Jersey
This is the first I am hearing about leaks from the front. Does he have a panoramic roof ?
DRkNESS
South Jersey
I’ll check my front, but I can’t see where it would leak minus the seal not being intact. :(
ksn240
I read a post a day or so ago. Dont remember if it was here or another forum but it was for a 2019. There was basically no glue/sealant at the top center of the windshield and that's where water got in. Yours is most likely the same issue. It seems Ram has some quality issues to work out.
RamCares
n/a
n/a
Hi BlownGP,
If your friend decides to have their dealership look into this, you can have them give Jeep Customer Care a call at 877-426-5337 in case there are any questions or concerns your friend may have while the truck is being serviced.
Lydia,
Ram Social Care Specialist
AnthonyD1978
N. Arizona
2019 Power Wagon
Fixing the leak should be easy. My concern is mold. I would push for a new headliner.
BlownGP
BlownGP
Houston/Baton Rouge
Hi BlownGP,
Lydia,
I will let him know. Thanks
