WTB
Status
Not open for further replies.
Dustin Steffey
Fernley, NV
Looking for rear suspension pieces to upgrade sway bar end links, control arms, sway bar, etc.
tidefan1967
Summerville, South Carolina
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Hellwig is the best option, and they have better endlinks as well you can get.
Graygoose
Oklahoma
Convert, for now.
small
What’s the difference between core to hellwig?
On the endlinks, probably not much, the Hellwigs were with the lifted sway bar kit, but both look good!
Dpressed1
Houston
I have a pair of rear sway bar links from core 4x4 for stock height. They are gray in color. Can send pics if interested
Dustin Steffey
Dustin Steffey
Fernley, NV
I put the icon coil in the rear which lifted the rear about an inch will those still work? If so I’m interested.
Dpressed1
Houston
If you’re currently using the oem links, im sure the core’s will fit. They are the exact length as oem links
kad
Hudson Valley, NY
5.7L HEMI
Do you have a rear sway bar now? If not, I've got an OEM one with links that I took off to install my Helwig/Moog link setup. Shipping could be expensive NY to NV though...
-K
Dustin Steffey
Dustin Steffey
Fernley, NV
-K
I have an oem one, I want the hellwig but it’s pricey.
Status
