RickH
If I were to add a block heater I might very well add a pan heater, too. They are available in foil based glue on kits all over Europe and should be readily available here as well. Both can be rigged with timers and t-stats.
That reminds of the old stove pipe and tiger torch stuck under the oilpan,lol. More then one truck burned to the ground though,but it sure made a vehicle start easily at -40F in about 5 minutes,lol
The trick is getting the propane to light in those temperatures. Don't mind the fuel leak.
As for a block heater on a gas engine, its a big world. You'd be surprised how much life improves with it when it gets below -20C.
Agreed. My rule in general.. is to never live anyplace where standing outside too long will kill you.... seems pretty logical to meif I lived there, the first thing Id do is MOVE LOL
Ive been in southern AZ with it 121, but never ever that cold...maybe 10 below, maybe a tick more...but not that cold.Agreed. My rule in general.. is to never live anyplace where standing outside too long will kill you.... seems pretty logical to me
yea cold is cold.....I love the heat. But, now that 120+ there is not as bad as 100* in like Mississippi...thats MUGGY!That's a little to hot for me.You can only take so many clothes off in public before they throw you in the loony bin,lol. But I've been where you don't shut anything off if it's running, as it might not start again in an hour,lol
Just found this... never seen anything like it.. block heater? Thought that was a diesel thing.
I did find maintainence records for this thing in French.... so I think it came from Canada... which might explain the need?
But water will freeze quicker than oil. And when it does it will expand greatly. So there is a risk of cracking the block/head. Only back up for that is your freeze plugsI prefer an oil pan heater over block heater. Who cares if your coolant is cold you're still. Trying to push cold molasses oil through your engine if the oil ain't warm.
We use 50-50 antifreeze which is usually good for - 60 I mix mine for about - 65 so. There are no worries about freezing.But water will freeze quicker than oil. And when it does it will expand greatly. So there is a risk of cracking the block/head. Only back up for that is your freeze plugs
Sent from my SM-G950U using Tapatalk
-65 are you adding any water to it or just straight anti-freeze,lol.That's a mighty syrupie mix at -65,lolWe use 50-50 antifreeze which is usually good for - 60 I mix mine for about - 65 so. There are no worries about freezing.
Sent from my SM-A530W using Tapatalk
It's like 25% water. [emoji23] Just enough to discolor it. Haha. It gets cold up here!!-65 are you adding any water to it or just straight anti-freeze,lol.That's a mighty syrupie mix at -65,lol
Pure water in a engine , that crap went out in what ,1920? Antifreeze is to protect the engine from rust, as well as cold temperatures . Also the boiling point is way higher. P.S. if you go too strong, you will lose ground , you can buy antifreeze rated at - 50or more these days.But water will freeze quicker than oil. And when it does it will expand greatly. So there is a risk of cracking the block/head. Only back up for that is your freeze plugs
