@Katonaj ,
So you have the 6" Zone with 5" rear coils , 1.5" spacers , stock wheels and 37" × 12.50” tireswith no rub at all ?
Did you install bills up front , if so what setting 2.1 or 2.8 "
As for your question above on what happens to the OEM ucas ball joints on the 13+ Rams .
Mainly the issue is with spacers up front as opposed to the Bilsteins , but the ball joint slowly migrates up and eventually pops out . This typically takes a while and is a slow process that shows itself with audible popping noise . This process is exaggerated by rough offroading and usually a non issue for street use . This is an example of the ball joint starting to migrate up on an OEM UCA .
IMO if you do not offroad often then just keep any eye on them , especially if you start hearing a popping sound up front . If yours start coming up , then just take it easy and order the Zone or Mevotech UCAS . I've had Mevotechs installed for over 30,000 miles with bill at +2.8" with no issues ...and I off-road lots and at times pretty rough .
Hope this helps !
Truck looks Awesome !
