Diablo sucks it...
Lhemi
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
The biggest thing I noticed was the transmission shifting. Everything seems tighter and shifts harder.
C120
Shifting is probably the biggest frustration with the truck. Tranny has absolutely no urgency when it comes to down shifting.
DavidRam
SoCal - Redondo Beach
2012 RCSB
Yep, me too. Tighter is the word. And much more responsive.
To be fair, I think the RCSB guys will obviously feel a much bigger difference than the QC 4x4 guys... What is the weight difference, 600lbs plus??
So if you figure horsepower to weight ratio (which I do not know how to figure), you will need quite a bit more to feel the same thing we feel.
Edit: the above post was the most vague, yet obvious thing I have said yet...
Lhemi
Lhemi
OKC OK
You sounded like you could have been running for mayor of Hemiville. :)
C120
Earlier today I went on Moe's performance to check out a few things and… well I am sure you know how it goes… before I know it I have six thousand dollars worth of parts in my cart! Guess I might need to get a job soon lol
popcenator
Omaha, NE
I have my eye on an Edge next... I just wish I had my eye on the money for it.
on the move..
Lhemi
Lhemi
OKC OK
Me too, I got to tell ya, last night sucked. I felt like my throat had swollen closed and I couldn't breath.
I guess the Demerol wore off now it's just suck town....
VolsRam
Franklin, TN
HEMI 5.7
I noticed earlier tonight that a bolt is missing from my S&B intake lid, leaving a nice open hole and an insecure corner to my intake. I still haven't installed the HF tune back to the truck from when I reset the computer last, so my question is should I wait until I get a screw to put into the hole before reinstalling the tune? I don't know if the opening will effect my throttle response too much
Lhemi
Lhemi
OKC OK
I don't think it will effect it at all...
VolsRam
Franklin, TN
HEMI 5.7
As I was reloading the tune I kept getting the check engine light with "Service the electronic throttle response" message. This has never happened. Any ideas? After I loaded the tune and started the vehicle it went away.
Jmhm17
Massachusetts
5.7L HEMI
I get the throttle light when I tune as well, it never comes back after the last key cycle tho. I always get nervous tho lol
VolsRam
Franklin, TN
HEMI 5.7
Always. I've never shut the door when loading it. I do pull the key out of the ignition when it says to turn key off.
VolsRam
Franklin, TN
HEMI 5.7
I even left the dome light on this time, and it never shut off like I expected it to.
VolsRam
Franklin, TN
HEMI 5.7
Alright everyone that has a HF 93 tune loaded. I decided to look at the parameters to see what I can find. If you wouldn't mind seeing if your parameters are the same or different I would appreciate it.
Cooling Fans AC Off:
High MPH HS Fan On = 193.99
Low MPH HA Fan On = 193.99
Cooling Fans AC On = 193.99
Idle:
Idle RPM AC Off in D = 0
Idle RPM AC Off in P/N = 0
Idle RPM AC On in D = 0
Idle RPM AC On in P/N = 0
Part Throttle Upshift:
1-2 at 15% APP = 1631.94
25% APP = 2015.93
33% APP = 2591.91
40% APP = 3647.88
60% APP = 5183.83
2-3 at 10% APP = 1816.91
20% APP = 1977.23
30% APP = 2030.67
40% APP = 2885.69
60% APP = 4969.80
RPM Shift Points:
1-2 RPM Upshift = 5850
2-3 RPM Upshift = 5850
Rev & Speed Limits:
Rev Limiter in Drive = 0
in Neutral = 0
Vehicle Speed Limiter = 185
Throttle:
Throttle Boost = 0
WOT Fuel:
WOT Fuel 1K-3.8K = 0
4K-4.8K = 0
5K-7K = 0
WOT Spark:
WOT MBT Spark 1K-3.8K = 0
4K-4.8K = 0
5K-7K = 0
WOT Spark 1K-3.8K = 0
4K-4.8K = 0
5K-7K = 0
Hope this helps explain why I'm having issues.
dvc357
Pulled the trigger on a Trinity
Got it yesterday
Took one hour to install.
If i hadnt read the notes in this thread, it would have been a nightmare.
Luckily i did, had a good idea what to expect and everything went perfect. That Diablo "Quick Start" booklet is worthless!
I got the unit from Sean at HF and it came witht his basic tunes so i loaded his 91 octane and drove a tank of gas through it. in one day. It raised my gas milage average from 14.9 to 16 .7 and thats by hand calculation. and seat of the pants horsepower increase is noticeable.
Cant smoke my tires but runs great.
Lhemi
Lhemi
OKC OK
Well at least this has helped 1 person...
