BadHabit2Break
I have my DSR1, just no time to install it.
Wish I had time to go to the auto show. Spoke to my audio dealer and they have a truck there with the alpine system running the DSR1. Told me they tone down the chime frequencies through the EQ and everything sounds good including the sat. Radio, phone calls etc. They're going to do a full tune and set up for me once it's in. He figures it'll take about 4 hours to dial everything in with the right equipment so pretty extensive. Hopefully I'm happy with the results. Only part already in was my front speakers. You know you spent too much on front speakers when they come in a briefcase instead of a box lol. Still a month from doing the install, but I'm getting less nervous and a little more excited now.
I'm seeing better reviews of the pac4, but it has fewer outputs. One of the members is running a masconi dsp and likes it. Have to think someone has a fully sorted dsp system where everything works well. I just haven't heard one. The update for the DSR1 looks like it includes a remedy for the tones and amp popping. Not sure about phone call and radio quality though.
I've noticed. As long as the 7 sounds good and I think it will I'll leave it alone. I was considering adding a pair of BLAM FR80 in the dash since they match into my BLAM 165 MULTIX as I thought it would bring the staging up nicely, but 2 more channels between the speakers, extra amp and larger DSP added up really fast, but once you get past 9 channel the difference to add a couple more isn't too bad.Be careful just adding additional speakers. More is not always better. I ended up with the 12 channel version because I needed 9 channels (3 way front, rear fill, sub) and my Bit One DSP only had 8. That was one very expensive channel. LOL
Just ordered one for my 2019 Bighorn. Has anyone else upgraded the sound in a 2019?
I Plan to run a passive 3 way setup in the front (Hybrid Audio, Unity). I have the 6.5 and tweeter from my Tacoma build that I removed, but now they offer a 3.5 with crossover that blends well. I hope the 3.5 will fit in the dash, I think it will. I'll stick the tweeter in the sail. Distance wise, I think the door 6.5s and the Dash are nearly the same, so hoping the timing will work in a passive setup. Tweeters will be a bit closer... will have to see. There is a chance I'll have to move that onto a separate channel so I can set timing. I've heard timing isn't so critical with Tweeters...
My question, even though the 6.5 and tweeter are on the same channel from the DSR1, I can change the levels of the tweeter level by adjusting the output levels for the tweeter frequencies correct on that one channel? The DSR1 looks like it does that, but I really just know enough about all this to be a little dangerous rather than effective.
I'm also a bit confused about the ohm resistors needed. I knew I'd need this if I tapped the speaker wires coming out of the factory amp, took them to line level, then amplified them. But I thought the DSR1 removed the need for those. If I remove the factory amp, plug the digital signal from the deck to the DSR1, then form there using RCA preamp to my amp, then to my speakers... where do the resistors go in that line?
Thanks for any suggestions!
