cummins 6.7
  1. B
    5.9 or 6.7 and which gerabox for towing?
    Hi together, I am thinking about switching to a cummins instead of mine 6.4l PW 2016. I tow around 7800 lbs 20 times a year and 4500lbs around every second weekend. We have steep mountains with around 14-18 percent slope. What combination of cummins engine and gearbox would be the best choice...
  2. K
    6.7 Cummins ECM failure and delete tune issues after having ECM rebuilt ...
    2008 Ram 2500 with 6.7 Cummins ECM failure and delete tune issues after having ECM rebuilt ... Facts: 6.7 Cummins ECM failed, sent it off for refurbishment, came back and ran once (60 miles), parked and failed to restart, towed home. Removed ECM and sent it back for second refurbishment...
  3. Csixinarow
    2016 ram 5500 Cummins codes u010c,p2bac,p003a
    Hi guys my name is Dave I have a 2016 ram 5500 6.7 Cummins engine. And got the codes u010c ,p2bac truck is in derate. I have performed a voltage test on actuator connector. I have first had about 10.5 volts pulled some wire cover off and went back to test key on and got 12 V at the power the...
  4. sgtmayfield
    P0740 Code Help
    Hey yall, New to the form and having some issues with my truck. Got a P0740 Code and my truck is acting sluggish and won’t shift into 6th unless I let my foot off the accelerator and then re apply the pedal. Haven’t noticed overheating but my MPG has dropped significantly. Just hit 220,000...
  5. D
    Neverending DPF issues - Trade in for Cummins or Hemi?
    Hello everyone - I need your opinions! I own a 2020 RAM 3500 Longhorn Cummins 6.7 HO with 26,000 miles, that has had chronic DPF issues since purchase. Aside from that, I really do love this truck. It's has DPF issues every 3-5,000 miles. They've replaced the whole entire emission system...
  6. B
    I want LED bulbs for my Ram 2500 and need help from the pros choosing the best brand!
    I own a 2014 Ram 2500 Laramie with projector headlights. I like the look of the stock headlights and fog lights on this truck but want to change the bulbs to LED. My dad owns a 2019 ram 1500 Limited and I love the color and output on his bulbs. Obviously I will never obtain the same quality but...
  7. J
    Help with Turbocharger 16 Ram 2500 Diesel
    I have a 2016 Ram 2500 Diesel 4x4 cummins In November, check engine light came on p0299 Took it to Mechanic They said $13k for a New Turbo I have no clue But I have a warrant I said fox it Got truck back Jan 16 New Turbo Now the Check Engine Light keeps coming back on P0299 Mechanic says I have...
  8. SilverbackBeast
    Intake tube
    Looking for anyone who is making intake tubes for 2500 Cummins for the 2022. Wanting an aluminum tube with the sensor plates for the 2022. Building my own intake box just needing the tube so I can power coat myself
  9. 2022 Tradesman
    1ST TIME DIESEL OWNER / CONFUSED
    Thanks for everyone who gave me advice. Really appreciated.
  10. ramportin1
    Been a long time! New to me 3500 CTD
    If any of you lon time members see this and know me, im sad to say Raiden (my white 07) is totalled :(. doing 55 through the clackamas river curves to get home and a deer jumped out to play chicken, like a idiot i tried to get skinny and hug the side of the road (which is a 25ish foot ditch down...
  11. B
    1st Time RAM HD owner
    Hey, ramforum. I've been lurking around this board for months, and I've found it a good resource, so I thought I'd say hello. I bought my first HD RAM about 6 months ago to replace my mint (but old) '95 Ford F-150 XL. It's a 2018 2500 crew cab with Tradesman trim, an 8-foot bed and the addition...
  12. C
    Water Damage - Dodge claims no warranty
    Hey everyone, I have a 2018 6.7L crew cab 4x4. purchased brand new in 2017 from Clovis Dodge out of CA. Had a terrible experience buying from them so I ended up taking my truck to the dealership across town (owned by the same company). September 2021 I was deployed and I returned to my vehicle...
  13. Chains
    Help 2016 3500 Dually no reverse
    Today I had my truck in neutra, switched from 2wd to 4wd, backed up a slight incline about 3feet, truck stopped. No pop, grinding, shuddered, hopping......nothing. Switched back to drive pulled forward no problem, switch back to reverse dead nothing. Switched outta 4wd and back into 2wd......no...
  14. NewGTGuy
    New to Dodge and this forum
    Hello all. After months of research, I just ordered a 2022 RAM 3500 Limited with a crew cab, 6'4 box, and a high output 6.7L Cummins. Just wanted to introduce myself to all the other members of this forum. I promise to always search first and ask second. ;) Thanks in advance for the copious...
  15. R
    6.7 Cummins coolant pipe.
    Hi guys! New here, hope that i can find help in here. So my truck is leaking coolant from the metal coolant pipe behind the turbo, but i can't find it anywhere. Spent the whole day looking for it. And now its driving me crazy! Does any of you guys know where i can buy it? And also the other...
  16. CharlieTheTexan
    Fuel filler
    I currently own a 2012 RAM 2500, no DEF, and I was looking to convert to the newer 2013+ capless filler system. Currently, it has the click-style cap, but I was wondering if anyone had done this before or could point me in the right direction for info?
  17. C
    68RFE issues
    So I’ve got some shifting issues with my 2013 2500 with the 68RFE (go figure). I’ve been doing lots of research and asking around and haven’t been able to figure out what’s going on. Whenever I shift into drive, it takes about 3-4 seconds. Also, when I downshift it takes longer than it should...
  18. C
    Slow shift into drive from reverse?
    Hello, I have a 2013 ram 2500 Cummins with the 68RFE and have had an annoying issue with going into drive from reverse. When I back out of my driveway and put it into drive to leave, I’m waiting for 2 seconds before the trans shifts and I can take off. I just replaced my VB with an upgraded...
  19. T
    Tuning Ram 2500
    Looking for info on getting a "Custom" tune for my 2021 Ram 2500. I have a Bullydog BDX handheld tuner, and in search of a dealer that has a preset tune they can send for me to download. I've called around places in my area with no avail. If anyone has experience/recommendations on a dealer that...
  20. D
    Exhaust brake help!
    I had the actuator on my 2011 Gen 4 6.7 cummins go out a couple years ago. I went ahead and purchased a whole new turbo and actuator and installed it. When I purchased it they said it was all plug and play and no calibration was needed. Now when i use the exhaust brake system, it stays engaged...
  21. J
    Cummins turbo actuator
    I have a bad actuator on my 2016 6.7 Cummins. I bought the OBDLink MX+ and now I am trying to figure out if the AlfaOBD can be used to calibrate the new actuator when I go to replace it?
  22. L
    Liquid and powder substance under passenger side
    This morning I went out to my truck (2018 Ram 2500 with 6.7 Cummins) and noticed two spots of fluid on the ground under the passengers side. after further inspection the left spot is a clear liquid, slightly oily. I’m thinking brake fluid. Definitely not ac the truck hadn’t been ran in about 8...
  23. J
    Ram 2009 Cummins - voltage fluctuation
    Hello - I have a 2009 Ram 3500 6.7 Cummins. Recently I noticed a “flashing”, lights dim and then back to normal. This cycles on and off for between 2-20 minutes. The voltage change is noticeable in the exterior lights, dash lights, dome lights, hand held voltmeter etc. When I turn the engine...
stevenmicheal
