heavy duty
  1. Infotainment.com
    2019-2024 Heavy Duty RAM Owners — A Digital Cluster Upgrade Is coming soon!
    If you’ve been wishing your 2019–2024 Heavy Duty RAM had the modern full digital instrument cluster found in newer models we’ve got good news. We are actively working on a Factory OEM Digital Cluster Upgrade for Gen 5 Heavy Duty RAM trucks. This upgrade brings a fully digital gauge display with...
  2. D
    Heavy Duty 4x4 Trans and Transfer Case for 2001 1500
    Does anyone know of any place that I can get a direct bolt up heavy duty 4x4 auto transmission for a decent price. It's going into my 2001 1500 with a 360 Magnum stroked to 408ci and will make around 470hp out of the box, but I may try to get more out of it in the future (probably 600hp max)...
  3. Pktatum95
    66 rfe swap?
    I’ve got a 2017 Dodge Ram 3500 Reg cab dually 4x4 with 4.10 rearend. I hotshot for a livin, so I do a **** ton of driving. Currently truck has 240k and runnin like a top. At 93k engine went due to lifter lock up on cylinder #8, sent metal shavings through the whole engine, so got a brand new...
  4. C
    Watch Idle Hours & Change Oil every 3k Miles to Avoid Engine Failure!!
    If you own 2014-2018 heavy duty with 6.4 Hemi; do yourself a favor and try to never idle engine and change oil every 3k miles or earlier. If you can’t do those 2 things, get rid of truck now! Just went 2 months without a truck due to engine failure and $9,000 later(for rebuilt) due to having...
  5. W
    2016 5500 RAM 6.4 No crank/no accessory/no start/full of errors
    2016 5500 6.4 automatic transmission Didn’t know proper forum to put under because heavy duty + electrical Shut truck off one night & went to start it the next day - had multiple error codes after being clear The night before Has had PCM replaced previously for different issue (AC failure + no...
  6. Pktatum95
    Maximizing mpg 6.4 hemi
    Hey there. Have a question guys. Wanting some of yalls opinions. I have a 2017 RAM 3500 6.4 hemi DRW Reg cab with 4.10 and 66rfe. 209k on the clock. Bought it brand new with 8 miles on it (I put 6 of those test driving it) Lifter failure at 93k. New long block courtesy of FCA. No issues...
  7. BandBFence
    Max Tire Size For Heavy Pulling
    Just lettin y’all boys know, 255/80/17 is the size. I don’t have to worry about getting stuck, I feel safe and secure on the road, and as an added bonus the truck looks awesome. Looks close in the back, it’s not. I could put another 5k on the bed. Super happy with the Toyo MTs.
  8. Oilfieldman
    2020 ram 2500 tradesman trailer tpms came with the truck
    We just bought the truck new last night and I noticed it has 4 trailer tpms sensors in a bag with the owner’s manual and also a little flat piece of plastic with 2 plug in connectors on it. It has the 5th wheel prep pack on it. Has anybody actually got this system to work yet? I’ve seen a bunch...
  9. PowerWagon2019
    aux lights wiring question
    Looking to add aux lights (light bar) to my 5th gen HD. Wiring is pretty straight forward except for the high beam trigger circuit. (allowing the ability to turn on the light bar only when high beams are on) I read where others have used the driver side white/green headlamp wire to drive this...
  10. J
    WINCH SIZE!?!?!?!?!?
    Good mornin to all the Mopar lovers out there. Anyways I am new to the whole 4x4 HD thing. Lil history, I grew up on the strip and the family is all about the go fast!!! So the mechanical know how I have. Wanted a change and something different to build. So I am gonna go for the rescue vehicle...
  11. Kyroptorin
    Engine Shutoff any thoughts?
    I have a 2017 ram 2500 bought brand new in 2017. 6.4L V8 4x4. Right now it has about 27k miles on it. So it’s snowed significantly over the last weekend and there’s still snow on the ground. On my way to work this morning I miss the entrance and have to turn around on a side street. I put my...
  12. pwjouster
    2018 TrailWhale PowerWagon Build Thread
    2018 Powerwagon! For those who dont know- this means: Ram 2500 CC SB SRW 6.4 Hemi 6 Speed-AT Lockers front and rear Disco Sway Bar Warn 12k Winch This is my powerwagon build. Daily Driver Flat South Florida. Minimal Towing Aggressive driver and The Trailwhale will be beat on. 6.4 HEMI S&B...
