lift height
  1. D
    Lift kit advice
    Hey guys it’s me again I had asked previously what size lift do I have here on a forum months ago turns out I had 4 inch rancho suspension lift but the shocks were very worn so I they were saggy already and creaked like crazy when driving or turning and the outer and inner tie rods were shot and...
  2. D
    Size of lift?
    i previously asked the size of my life but I have the measurements now I measured from the exact center of my wheel to fender like it shows in the picture it was 24.5 to 25 inches exactly i thought i was 25 but my tape was down a bit more had to put it exactly in the middle so (24.5 for the...
  3. D
    Asking what size lift do I have pls? rear look higher than the front ? Bough truck from Texas it’s a lonestar edition it’s the gray truck on the pic
    Asking you guys the experts for help asking what size lift or leveling kit does this truck have it’s currently sitting on 31s both rear and front and wondering because the rear looks higher than front sometimes which is the opposite of squatted trucks just bought the truck a 2010 lonestar...
  4. Ktaylor_j
    Looking to get 3” lift w/ 5100s + Springs
    Hey guys, so I’ve weighing my options for obtaining a true 3” lift in the front of 2017 Ram 1500. I have a new set of 5100s (already have a set installed in my 2010 set at 2.8 and love them) but I’m wondering if this time around about getting longer front coils (2.5” eibachs) and then setting...
  5. Z
    2024 Ram 1500 Laramie 4x4
    Hi all! First time poster, I am looking to get some work done on the truck as I love the look and will be doing some light off roading with it. Tossed up between a 2.5 inch lift and a 3.5 inch lift. Will probably be running Falken Wildpeak A/T4W 33's if they fit on the stock rims. Any...
  6. G
    Front suspension lower
    I have a 2013 1500 with 60,000kms. After installing Bilstein 5100 and bags in the rear, the front sits slightly lower. What is the best way to fix this and level the truck nicely?
  7. D
    Rim/Lift help please
    We have a stock 2016 Ram 1500 RT. My boyfriend is looking at a 6" lift. He's been doing some online research and finding differing info. He's looking at 22" wheels with either 35 or 37 inch tires. He's seen that the lift and wheel/tire combo could cause trans issues, but he's also seen that it...
  8. D
    4in or 6in Lift??
    Hello, I have a 2015 ram 1500 with a “4in lift” I’m not too sure because compared to a lot of other trucks mine seems to sit higher. Could someone help me out? Thank you! The second picture is with 35s
  9. b8ascrub
    2021 Bighorn 2” to 6”
    Well I made the leap and bumped up from a 2” level to a full blown zone Offroad 6” lift with a complete fox suspension. The credit goes to @Quick_Shifter for his extreme knowledge and attention to detail on these Rams. If you’re thinking about doing any suspension work and you want to spend...
  10. G
    Bilstein 5100 Rear Shocks and TufTruck Springs
    Looking at upgrading my OEM springs on my 2018 big horn to Tuftrucks but wasn’t sure which ones to get. Right now I have 1” spacers in the rear with bilstein 5100 shocks. Would adding the TufTruck 1223VT springs over extend the rear bilsteins? Everything I read about the bilsteins says they only...
  11. K
    18 ram 2500 leveling help
    I'm looking at putting a leveling kit on my 2018 ram2500 6.4. I found a 2.5 rough country with shocks and was thinking of getting it. And I'm looking at 20x9 fuel assault for it. My question is with 2.5 in the front should I get a 1" spacer in the back also or will it sit level without it. I'm...
  12. Alec Broschart
    Worn out springs causing rear to sit lower than front? Help
    Hey guys, recently had my 2012 ram 1500 lifted. There's been a couple of issues, the mechanic couldn't use the shocks that rough country sent me because they would simply fall out when the truck was lifted for some reason, he kept mine in their which didn't seem to cause any problems. However...
  13. FloridaHemi
    Comparing true lift heights (RCX, BDS, Superlift, Mopar, etc.)
    Hey everyone, in the process of purchasing a RCX 4in lift for my 17' Laramie longhorn. When looking at pictures of 4in lifts from all the various manufacturers, I notice that some look higher than others. I am specifically talking about folks running 35's on stock wheels with a 4in suspension...
  14. H
    Lifting my 2007 Reg Cab
    I know I know, there are a bunch of 4 vs 6in threads on here already. But a lot of them are outdated, and the photos don't load anymore. So here we go. I have 2007 5.7 Hemi Reg Cab 4WD at stock height. I currently have 20in wheels and 31in tires, going to keep the rims and do 35s. This is my...
  15. WamBam
    replacing coil spacers with 3inch coils
    I have a procomp 4inch lift kit and it has coil spacers in the rear that also relocates the track bar. im trying to buy 3inch coils and get rid of the spacer but when I looked at it I realized that the track bar situation was different. any ideas of what to do??
  16. Heber Perez
    Lift options
    Hello to all I am toying with the idea of lifting my truck I own a 2016 RAM 1500 Lonestar 5.7 Hemi 2WD. I first have to figure out the tires, but I would like to know your opinion on what would be my budget friendly options for at least a 2" lift, without compromising on quality and performance...
  17. SportPete
    Rancho quick lift with zone 4” question
    hello all, Im going to be installing a zone 4” lift with rear 3” coils (no spacer). If i used the rancho quick lift struts assemblies in addition to the zone lift, would that level me out? Thanks in advance
  18. Matthew Smith
    Truck leveling
    I’m leveling my 2wd 1500 I’m done to two options the rough country replacement spring that’s a 2in level or a supreme suspension 3in spacer idk what best bet is either a spacer or a spring. And I was gonna upgrade the UCA’s I was wondering if a 4wd upper will fit a 2wd cause I really don’t...
  19. N
    2006 Megacab 1500 leaf springs
    Hi so I bought this used 2006 Megacab 1500 Hemi 4x4 The truck looks lifted... but I can't find spacers on my front springs. On my rear leaf springs I do see about 2" spacer on the springs... and 4+1 leafs So my questions: - what is stock height? - do they come with that spacer between rear...
