quad cab
  1. E
    2023 1500 Quad Cab Classic Cap
    I had an ARE fiberglass cap put on my truck and it didn't fit properly, work purchased the cap via the vin number for the truck and ARE states they sent the right cap. The front top of the cap hits the top of the truck cab. ARE would not budge on sending the correct cap. Now work purchased a...
  2. S
    Cutting into the body
    Hey so Im having a special box ordered for my 2021 1500 classic quad cab by fox acoustics. Its a vented box for 2 12" subs but the problem is that the amount of air that the space under the seats provides isnt enough. So I am wondering if I can cut a port through the little wall that separates...
  3. E
    ram 1500 2006 mods suggestions?
    i have a 1500 2006 4x2 5.7 hemi quad cab it has 432000 km i want to add some boost or hp but i dont know what to add and what dont, i been reading different posts of cold air intake some say it work others that doesnt ,so go ahead and drop your suggestions and if you have some pics better(it...
  4. G
    Quad Cab Steps/Running Boards
    I just purchased a 2020 Big Horn Quad Cab and I underestimated how high the truck is. I like the look of the factory installed side steps but I am having trouble determining the OEM part number for the stainless steel wheel-to-wheel running boards for the quad cab model (the dealership is far...
  5. jpmx0
    Fitment of carpet for 2005 Quad Cab from other years?
    Hi guys - I've enjoyed and learned on this forum for a while but finally need to break down and ask my own questions. Probably a long shot, but would carpet from a 2006 Ram 1500 Quad Cab fit the same model 2005? By "fit", I mean molded and shaped in the same locations, same distance to rear...
  6. T
    Single to Dual exhaust
    I'm new to this forum and was wondering what your thoughts are on converting my 2011 Ram 1500 Quad Cab 5.7 from a single exhaust into a dual exhaust. I'm in no way mechanically inclined, so anything helps.I want to have a full custom exhaust, complete with H-pipe and Flowmaster Super 40 series...
  7. Landon Boyd
    Mystery Truck
    I’m brand new to the group so hopefully I get all this right. Recently I purchased a 2002 Dodge Ram 1500 4.7 with 98,000 Miles. The truck had quiet a bit wear and tear but not awful by any means. Just a rip in the seat, cracked dash, blower motor resistor. exhaust leak, airbag light, different...
  8. H
    Quad Cab lowering issues
    I had lowered my truck sometime last year. did the flip kit on the rear and lowering springs in the front. Not really sure if it was 4" or 6" drop on the rear. Anyways, the issue i had with the drop was that the drive shaft was rubbing on two different places. one of them is was on the hanger...
  9. MoparFin
    MoparFin’s 18
    Here is my 2018 Express. It’s a V6, 4x4, 3.55 gears. So far I have cut and PD’d the antenna, PD’d the exhaust black, added a Rough Country Tri-fold soft bed cover, Reese load bar and have the Rough Country Floor Armour floor mats on order (sent back, didn't like the material, they were...
  10. P
    Looking for New Wheels and Tires
    I have a 2011 2500 Ram currently sitting on the stock steel wheels, 17s. I am looking for new wheels and tires but don't even know where to begin honestly. I've seen some tire conversion charts around, but I can't even really picture what those sizes would look like actually mounted on a truck...
  11. M
    5.7 Hemi swap for a 6.4 Hemi into a 07 1500 QC LB 4x4
    I know it sounds silly, maybe even a little insane. But I love my truck. Yes it’s an 07 quad cab long bed 1500. You don’t see that many of them, well at least I don’t. And you can’t even get a 1500 crew cab long bed anymore, unless it’s a 3rd gen or a 2500. Okay so what are your all’s thoughts...
  12. Aidan Crombie
    Suggested modifications for a 2014 1500?
    Good day to you! I have owned my 2014 Ram 1500 Express Quad Cab for almost a year now and I do indeed love her. However! I am very keen to start working on some modifications, both performance and cosmetic. I don’t have the funds to always drop $800 on a new exhaust system or $2000 on new rims...
  13. servi53
    my new 05 power wagon
    recent purchase
Carbary
