ticking noise
  1. T
    2022 1500 5.7 Advice Needed..
    Help needed.... I recently purchased a 2022 1500 5.7 v8 with roughly 45k miles on it. I love the truck due to its cab size, smooth ride and performance at higher speeds. I bought in doing what I felt was thorough research although I fully admit I am trying to build my mechanical mind in the...
  2. P
    2020 1500 Hemi Tick Please Help!
    My 2020 1500 5.7 hemi is ticking and I can't figure out what it is. The truck has 59,500 miles on it and less than 450 idle hours. There is a loud ticking noise during idle, cold and warm, and it also matches the RPMs. I took it into my local ram dealership and they replaced both exhaust...
  3. KadenJ
    Inconsistent ticking on acceleration.
    Hey all! My 2005 4x4 1500 dodge has started an inconsistent ticking upon acceleration. Sometimes it occurs when I turn corners, other times I could be driving in a straight line. In either situation, it's a hit or miss as to whether I will be able to hear it at all. At first, I believed that...
  4. F
    Best oil and filter to use with 4.7 tick?
    Hi all, this is my first post here and still figuring out how to use the forum. I have a 2011 SLT 4.7 with a tick when cold, goes away when warm. The engine has 86k on it. I’ve heard a bunch of different recommendations for oil/ oil filter combo. What would you guys recommend with my situation...
  5. W
    Ticking noise
    I have a 2022 ram 1500 5.7 with etorque. I was pulling in the garage yesterday and noticed a ticking noise coming from the wheel well area on the passenger side. Only makes the noise when it is warmed up and at an idle. It is rpm related. Bought the truck new and it has 15000 highway miles. Oil...
  6. MarcoFuc
    Lifter tick? Or exhaust tick?
    https://youtube.com/shorts/6jw79L3tuUg?feature= https://youtube.com/shorts/16Rdjj7SRnk?feature=share Here are two links to sounds I’m experiencing from my 2013 ram 1500 sport with 5.7 hemi. I am trying to get a better idea what it might be, I’m stuck between lifters or exhaust leak but I had...
  7. M
    Hearing ticking
    I have a ticking sound coming from my engine area, i don’t think it’s the hemi tick( I could be wrong) it sounds like A Bicycle’s tick I don’t hear it while idle ing and I can hear it from 40 down to 0 it goes away if I give it gas or break but only if I give a decent about of gas.
  8. C
    Watch Idle Hours & Change Oil every 3k Miles to Avoid Engine Failure!!
    If you own 2014-2018 heavy duty with 6.4 Hemi; do yourself a favor and try to never idle engine and change oil every 3k miles or earlier. If you can’t do those 2 things, get rid of truck now! Just went 2 months without a truck due to engine failure and $9,000 later(for rebuilt) due to having...
  9. waqasrishi
    2012 RAM 1500 running really rough after sand dune drive
    Hi, I am new here and I own a RAM 1500 2012. I recently got it serviced and the truck was running really smooth after the oil and filter changes. I drove the truck in the sand dunes here in Qatar. If you have any experience driving in the dunes the ride is pretty rough at times specially...
  10. M
    Noise - Transmission
    I have searched this site and found some clues, but thought I would send out a post to see if there was something more definite. When slowing down, my 2013 5.7 4x4 sounds like a diesel. It will only last a few seconds or more. So, when I'm heading down the road at about 40MPH, I hear the noise...
  11. R
    Exhaust leak... again
    Got my exhaust leak fixed in May now in December it is leaking again not sure what to do. Should I call the dealer and see if they will back their work since I’m assuming it wasn’t done properly. 2011 ram 1500 5.7 with exhaust manifold leak please help
