Exhaust leak... again
Ryley
Alberta, canada
5.7 L
Got my exhaust leak fixed in May now in December it is leaking again not sure what to do. Should I call the dealer and see if they will back their work since I’m assuming it wasn’t done properly. 2011 ram 1500 5.7 with exhaust manifold leak please help
Tach_tech
5.7L HEMI
Are you sure it’s the same side?
I would at least phone them or take the truck back and mention the previous repairs and ask them to look at it.
Pull Ya
Cedar Creek, Tx
Is the leak coming from the same place? Maybe they broke a manifold bolt????
Jay
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
What did the dealer fix? Did they replace the exhaust manifolds or just replace the bolts and gaskets?
willis123
nj
A lot of people buy new manifolds see the issue is they will re warp i sand down my old ones to be flat again and they never re warp set of new bolts its been years since mine have leaked.
Tach_tech
5.7L HEMI
Gaskets and bolts and they said they will cover it
I’ll bet that those manifolds are warped to hell. The spec is like 0.008”/foot. Most manifolds I take off are around 0.050”. Chances are they just stuck the old ones back on. I don’t think I’ve pulled a manifold off that wasn’t warped beyond spec. That’s probably why you’re having an issue again.
Dark Knight 500
Alberta
Mopar warranty on dealer installed parts is 2 years parts and labour
Fitz-0518
Veteran 66-68
Central California
As stated, this is exactly what happened on my 6.4 2500. Dealer replaced gaskets broken bolts but did not machine plane or replace the manifolds. Exhaust leak was worse.
tantore
texas
installing shortys is a great idea and will eliminate the leaks
